Date/Time: Sat, 23 Nov 2024 15:30:21 +0000
getting new PC how to see / rst pwd?
View Count: 94
[2024-08-12 19:11:07] |
User360283 - Posts: 504 |
thanks
[2024-08-12 19:51:52] |
There is not a way to view the password that you are using for your Sierra Chart login. If you do not remember the password, then you can reset it at the following link: https://www.sierrachart.com/PasswordReset.php Just as an item of note, the password that is set within the software for your "Current Selected Service" can be viewed by selecting that field and then selecting the "Show" button. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
