Date/Time: Sat, 23 Nov 2024 14:51:34 +0000
Possible to show and enable trading on chart of ES but make the trades execute on MES?
View Count: 164
[2024-08-12 15:25:28] |
User685094 - Posts: 2 |
Hi, just wondering is it possible to show and enable trading on chart of ES but make the trades execute on MES contracts, without needing to open separate chart of MES to trade? Thanks |
[2024-08-12 18:56:38] |
Yes, you can do this. Refer to the following setting that makes this happen: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
