Date/Time: Sat, 23 Nov 2024 15:36:16 +0000
Problème avec le flux rithmic et le carnet d'ordre
View Count: 136
[2024-08-12 13:19:56] |
Super Pigeon - Posts: 1 |
Bonjour, En suivant scrupuleusement les instructions de connections du flux rithmic, j'ai plusieurs problème : - La fenêtre de log spam les erreurs de connections - Le graphique principal fait que de recharger les données (à chaque mouvement de prix il semblerait). Mais il est bien actualisé en temps réel - Le carnet d'ordre n'affiche que le prix actuel. Tout les ordres des autres sont invisibles. J'ai envoyé via sierra chart les log. Ci-joint une photo du carnet d'ordre vide. |
Private File |
[2024-08-12 17:38:39] |
From Google Translate: Hello,
By scrupulously following the connection instructions of the rithmic flow, I have several problems: - The log window spams connection errors - The main graph only reloads the data (at each price movement it seems). But it is well updated in real time - The order book only displays the current price. All the orders of the others are invisible. I sent via sierra chart the logs. Attached is a photo of the empty order book. First, refer to the following, as we see symbols that are not recognized by Rithmic (such as BTCUSDT-BINANCE): Rithmic Trading Platform Service: Frequent Reconnections Then, with regards to the Order Book, the issue there is that although you have activated the "CME with Market Depth for Non-Professional Trading Accounts" with our Denali Exchange Data Feed, you have not connected to your live, funded, futures trading account. We can see this by your "Verified Until" date for your account, which is currently showing as "0000-00-00". Refer to the following regarding this: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Therefore, you are getting the data from Rithmic, and we think you are not setup to get the order book data from them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
