Date/Time: Sat, 23 Nov 2024 15:35:55 +0000
Sierra chart approved brokers for Namibians
View Count: 113
[2024-08-12 13:15:25] |
User703646 - Posts: 1 |
Dear Sierra chart Could you give any advice on which brokers are compatible with sierra chart and approved to use for future and forex for Namibian citizens ? The consequences of using Interactive brokers are not worth it. |
[2024-08-12 17:31:57] |
We simply do not know. Sierra Chart has support for Interactive Brokers and brokers that use CQG, Rithmic, or Teton order routing services. You would need to find a broker in your area that supports one of these order routing services. Just be aware that with CQG the broker also has to allow the use of Sierra Chart, so it is possible that a broker that uses CQG would not work with Sierra Chart.
