Date/Time: Sat, 23 Nov 2024 15:15:24 +0000
Display only VPOC
View Count: 133
[2024-08-12 11:51:26] |
User753526 - Posts: 51 |
Hi I know that I can display thew VPOC using a Volume Profile however is there a way to display the VPOC as TEXT on the RH Side without printing the volume profile on the chart? I have used Volume by Price but unable to do this without havent hte Volume Profile displaying. My aim was to just have the 5D and 20D VPOC printed as text on my chart without the profile itself printed. |
[2024-08-12 15:00:13] |
User84094 - Posts: 47 |
Use "Volume Value Area Lines" Study. And change Vol Value Area High and Low to Hidden |
Attachment Deleted. |
[2024-08-12 18:32:56] |
Also, if you do not want the line, but you want the Price or Label displayed on the right, then set the "Draw Style" for the POC subgraph from the "Value Area Lines" study to be "Subgraph Name and Value Labels Only". Refer to the following: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) And then turn on the Name and/or Value label you want and put it where you want to see it: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
