Date/Time: Sat, 23 Nov 2024 15:11:18 +0000
I want to create a simple Volume Profile Per Candle Stick
View Count: 181
[2024-08-12 07:40:06] |
user111122 - Posts: 1 |
I've been trying for awhile to create a simple Volume Profile/Per bar, with a 40% value area highlighted, poc line, and the candle stick to the left of the volume bars. I can't seem to get it. Can you help me out?
[2024-08-12 17:04:21] |
Refer to the following for how to setup a Volume by Price profile per bar: Volume By Price Study: One Volume Profile per Chart Bar Refer to the following for the Value Area: Volume By Price Study: Value Area Percentage Refer to the following, and the Input below it, for the POC: Volume By Price Study: Highlight Point of Control There is not a way to have the candlestick offset to the left of the profile. The profile will always be on the candlestick. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
