Date/Time: Sat, 23 Nov 2024 14:48:05 +0000
check up list at starting -- Ground Zero
View Count: 158
[2024-08-11 18:59:35]
User838995 - Posts: 16
Hi
I am a total beginner and want to make sure my Account, Teton, Denali Exchange Data Feed is running correctly and not on Delayed Data. I have subscribed to $2. Non professional data. Also that My account is connected properly.
Anything else I should be vigilant about before live trading? Thank you
[2024-08-12 02:03:43]
Sierra_Chart Engineering - Posts: 17145
Tell us one of the CME symbols you want real-time data for.
Your account does look set up correctly.
[2024-08-12 11:37:15]
Thank you for replying.
https://www.sierrachart.com/image.php?Image=1723459581782.png
CME symbols want real-time data for: MNQU24_FUT_CME.
where Can I check for the list of symbol allowed with my DATA plan?
I have Denali Data feed plus Teton with Package 10 Running correctly? Just to reconfirm.
Currently Practicing in Sim1 Mode, what changes do I need to make when transitioning into Actual Trading?
Ever since 2400 ticks chart is added to chart book, my actual trading 600 ticks chart is off-sided on screen. The Arrow at the Bottom right hand corner is not visible at all and I can't click on the arrow to operate it. How do I fix this? I don't close the "NQ 2400" chart for the fear of loosing it and not finding it when I need it at a later date. you can see the "NQ 600"chart position in above linked image.
I will like to change the name of Chart book to be reflecting MNQ Emini Micro. Currently Chartbook name shows "1-Micro Emini SP.Cht" under File and at The top LEFT side of Chart. Have tried so many ways but it remains same under File- Chart.
Sorry, not easy to navigate Sierra Charts at the beginning.
Thank you for helping.
K.A
[2024-08-12 17:26:38]
You have the "CME Non-Professional top-of Book" exchange active. So you have access to instruments traded on the CME exchange. You will see most items on the "File >> find Symbol" window under the "Futures - CME" section. But if you want to view all the symbols for that exchange, you would need to look it up on the CME Group website. The Following link is setup to show this:
https://www.cmegroup.com/markets/products.html#exch=CME&sortDirection=desc&sortField=oi
Yes.
You just need a live trading account and be connected to it (which it looks/sounds like you have done) and then select "Trade >> Trade Simulation Mode On" to remove the checkmark for this item so you are then trading live. Refer to the following:
Trade Menu: Trade Simulation Mode On (Trade menu)
We do not understand this. The image you provided shows the 600 Trades chart just fine. We need more information or a different image showing your entire desktop so we can better visualize what you are seeing.
To change the name of the chartbook, make sure it it the active chartbook and select "File >> Save As" and give it the new name you want. You can then delete the chartbook with the old name. Refer to the following:
Chartbooks (Workspaces): To Save a Chartbook
Chartbooks (Workspaces): Deleting a Chartbook
