Date/Time: Sat, 23 Nov 2024 15:35:27 +0000
Turn Display Volume In Bars in VbP for TPO Chart study on and off with control bar button
View Count: 186
[2024-08-10 23:52:20]
User755495 - Posts: 14
Sometimes I want to see volume numbers in the VbP for TPO Chart study, and sometimes I do not want the numbers to show on the chart. Is there a way to make a control bar on-off toggle button for this element of the study so that I can avoid having to go to chart studies, open the VbP for TPO Chart study, go to settings, scroll down to Turn Display Volume In Bars, and then chose None or one of the other options? A simple click on a control bar button would be a great convenience (similar to the control bar button I have that allows me to toggle hide or show drawings from other charts).
Many thanks for your thoughts, and also for a great product.
[2024-08-12 15:55:50]
There is not a built-in option for this, but you can create a custom study that can do it. Refer to the following:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
sc.SetChartStudyInputInt()
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
