Date/Time: Sat, 23 Nov 2024 14:52:00 +0000
Editing Delta Values, ATR
View Count: 214
[2024-08-10 01:24:17] |
aygh - Posts: 14 |
1 I saw on another SC that you could add ATR to the chart in this format: ATR=4. How do I do this? 2 (Numbers bars calculated values) How do I make buyers turn green when they are more than sellers, and sellers turn red when they are more than buyers? 3 Is it possible to have the Min Max Deltas (above footprint bar) to change color when: - they are within a percentage of the ask bid diff (below footprint bar)? - they are in a range (for me 0 - 5)? See attached image |
Screenshot.jpg / V - Attached On 2024-08-10 01:22:17 UTC - Size: 495.17 KB - 49 views |
[2024-08-10 02:13:28] |
aygh - Posts: 14 |
Is it possible to color the numbers in the Cumm. Sum of Ask Bid Vol row in such a way it turns green when the number preceeding is lower and red when it's higher?
Screenshot 2024-08-09 220846.jpg / V - Attached On 2024-08-10 02:10:58 UTC - Size: 342.79 KB - 34 views |
[2024-08-12 14:08:05] |
1. We have no idea what you saw or even what you are wanting to accomplish. The Average True Range (ATR) is a value determined from the data, not something to be set. If you are wanting something specific, then let us know what it is. 2. There is a not a way to do this. The only coloring options for the Numbers Bars Calculated Values are to color based on the "Auto-Coloring" option for the subgraph, or to use the "Color Background Based on Value Percentage". Refer to the following: Chart Studies: Subgraphs Tab >> Auto Coloring Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions You can put some kind of marker or something in the main chart graph to let you know when this situation occurs. Refer to the following: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars 3. This can be done with the "Color Bar Based on Alert Condition" study. Refer to the following: Color Bar Based on Alert Condition 4. Same answer as #1 above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-13 04:43:33] |
aygh - Posts: 14 |
The attached Screenshot shows the countdown timer. Is it possible to have the ATR displayed in this format?
[2024-08-13 14:18:10] |
Refer to the following: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
