Date/Time: Sat, 23 Nov 2024 15:20:37 +0000
Market Depth ONE LEVEL ONLY
View Count: 161
[2024-08-09 18:24:23]
TopGunTrader - Posts: 172
Can you add feature to Market Depth to show the colors for just ONE level. It gets way too busy with past colors and with other indicators often unreadable and sometimes colors over indicators. I only care about current volatility I'm sure half the users would want this as we could add it to all charts and longer term 30m just show HIGH 250+ liquidity in ES for example. I'd add it to almost all charts to make sure I'm aware of where liquidity is.
There's no way now to use it on most charts as far as I'm aware just too busy past liquidity has little use to me.
If this is possible would love to know how to do it.
[2024-08-09 18:37:44]
This is something that is being worked on, but we can not say when exactly it will be made available.
In the meantime, a workaround for this is to use the Market Depth Historical Graph. We have attached a Study Collection that is the Market Depth Historical Graph setup to display Market Depth values greater than 250 on the right side of the chart. The rest of the graph is displaying, but it is set to be the same as the background (black in this case), so you do not see the blocks.
Refer to the following for how to use a Study Collection provided by Support:
Study Collections: Using a Study Collection Provided by Sierra Chart Support
attachmentMDHG-ValuesGT250.StdyCollct - Attached On 2024-08-09 18:37:41 UTC - Size: 18.56 KB - 101 views
[2024-08-09 19:26:34]
Awesome thank you so much and happy to hear its in the works will help me and others so much!
