Date/Time: Sat, 23 Nov 2024 15:06:32 +0000
Historical Chart Data
View Count: 106
[2024-08-09 17:57:57] |
ryanxdiaz - Posts: 3 |
Good Morning, I'm attempting to chart replay days that are months previous to current day to back-test but all the data on those days I'm attempting to back-test on shows very spotty/missing data. Things I've done so far: - I've made sure all my charts within the chart book have the date range and/or number of days that will accommodate this date I'm attempting to back-test on. - Deleted and re-downloaded the data via manually deleting the file from the machine and deleting via shortcut menu action item "delete and download data" - My data services is set at 1 tick Type of charts I'm using: - Naked Candle Stick Chart - Number bars/Foot print chart with total numbers Type of chart I'm NOT using: - DOM I've also searched the public support ticket board and couldn't find anything for this issue that doesn't suggest something I haven't already done. Thank you in advance. |
[2024-08-09 17:58:47] |
You need to set your chart to be a "Continuous Futures Contract Chart" for what you are wanting. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-09 18:31:11] |
Just followed the documentation you referenced and it worked. Thank you very much for your help.
