Date/Time: Sat, 23 Nov 2024 15:35:49 +0000
Did interactive broker change their Symbol format for options ?
View Count: 153
[2024-08-09 16:13:55] |
GravisHTG - Posts: 306 |
I am connected with IB to my sierra chart and I try to get option data feed from this SPY-OPT-20240809-431-C-SMART-100-USD But nothing is feed into the chart and it said - Symbol settings not found for current service I wonder - did they change their format for options ? Normal symbol data feed : AAPL-STK-SMART-USD - is working properly thanks in advance. And do you have other option we can get data for option in sierra charts ? I dont mind paying for external market data provider. Date Time Of Last Edit: 2024-08-09 16:15:42
[2024-08-09 17:30:22] |
You would have to ask Interactive Brokers about the symbols. We do not know. There is not another options data provider that works with Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
