Date/Time: Sat, 23 Nov 2024 15:10:31 +0000
URGENT: not getting data
View Count: 1286
[2024-08-09 14:52:15]
User472677 - Posts: 350
I subscribe to the Sierra Chart real time data feed. My charts were working just fine. Most important to me is being able to see premarket data on a day chart such as SPY. I noticed that I was getting delayed data so I went to Global Settings -> Data/Trade Service Settings -> Common Settings and changed Allow Support for Sierra Chart Data Feeds to Yes. Now I am not getting any new data for today on day charts. I have deleted and downloaded all data. I have restarted Sierra Chart. I am getting today’s data on intraday charts. For me this is urgent. Can you please provide directions to fix this issue?
[2024-08-09 15:14:39]
What is the symbol of the daily chart for which you are having a problem?
[2024-08-09 16:35:05]
It is happening with all of them: SPY, MSFT, AAPL, EXPE, etc.
[2024-08-09 17:38:19]
Please get us an image of one chart for which you are having this problem by following these instructions:
Then please get us your Message Log for that same symbol by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-08-09 23:40:23]
Here is the chart: https://www.sierrachart.com/image.php?Image=1723246766765.png
Here is the log:
2024-08-09 19:36:34.844 | Software version: 2609 64-bit
2024-08-09 19:36:34.844 | Primary Thread ID: 36604
2024-08-09 19:36:34.844 | Usage end date: 2024-12-23
2024-08-09 19:36:34.844 | Enabled for: Sierra Chart Historical Data Service.
2024-08-09 19:36:34.844 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-08-09 19:36:34.844 | Enabled for: Delayed Denali Exchange Data Feed.
2024-08-09 19:36:34.844 | Enabled for exchange2: US Equities Consolidated Tape
2024-08-09 19:36:34.844 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-08-09 19:36:34.844 | Current selected Data/Trading service: SC Data - All Services
2024-08-09 19:36:34.844 | Custom symbol settings values: enabled
2024-08-09 19:36:34.844 | Chart Update Interval: 400
2024-08-09 19:36:34.844 | Intraday Data Storage Time Unit: 0
2024-08-09 19:36:34.844 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-08-09 19:36:34.844 | 2024-08-09 23:36:34 Local computer time in UTC
2024-08-09 19:36:34.844 | 2024-08-09 19:36:34 Local computer time in SC Time Zone
2024-08-09 19:36:34.844 | 2024-08-09 23:25:46 Server time in UTC
2024-08-09 19:36:34.844 | Local computer UTC time and Server UTC time difference: 4 seconds.
2024-08-09 19:36:34.844 | Program path: C: (deleted for privacy)
2024-08-09 19:36:34.844 | Data Files path: C: (deleted for privacy)
2024-08-09 19:36:34.844 | OS Version Number: 10.0
2024-08-09 19:36:34.844 | Locale Setting: C
2024-08-09 19:36:34.846 | DLLs: sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll
2024-08-09 19:36:34.847 | Allowed protected custom studies: SST_FreeBundle
2024-08-09 19:36:34.847 | Crash reporter started: true
2024-08-09 19:36:36.376 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 443
2024-08-09 19:36:36.377 | DTC Client socket (4) | Creating socket.
2024-08-09 19:36:36.377 | DTC Client socket (4) | New receive buffer size: 0
2024-08-09 19:36:36.377 | DTC Client socket (4) | Connecting to IP: 38.103.112.179.
2024-08-09 19:36:36.430 | Denali Data Feed | Network connection to server complete.
2024-08-09 19:36:36.430 | Denali Data Feed | Starting socket receive thread.
2024-08-09 19:36:36.430 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-08-09 19:36:36.504 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-08-09 19:36:36.504 | Denali Data Feed | Sending logon request message.
2024-08-09 19:36:36.677 | Denali Data Feed | Received logon response.
2024-08-09 19:36:36.677 | Denali Data Feed | Server Name: RealTimeServer.
2024-08-09 19:36:36.677 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-08-09 19:36:36.677 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3
2024-08-09 19:36:36.677 | Denali Data Feed | Failed connections: 45
2024-08-09 19:36:36.677 | Denali Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:36.678 | DTC Client socket (4) | CloseSocket call.
2024-08-09 19:36:36.678 | Denali Data Feed | Disconnected from the server.
2024-08-09 19:36:36.678 | Denali Data Feed | Data feed disconnected. Will reconnect in 5 seconds.
2024-08-09 19:36:36.678 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:36.725 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-09 19:36:36.725 | DTC Client socket (4) | Closed.
2024-08-09 19:36:38.051 | File >> Disconnect selected.
2024-08-09 19:36:38.052 | DTC Client socket (0) | CloseSocket call.
2024-08-09 19:36:38.052 | Denali Data Feed | Disconnected from the server.
2024-08-09 19:36:38.052 | Delayed Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:38.053 | DTC Client socket (3) | CloseSocket call.
2024-08-09 19:36:38.053 | DTC Client socket (3) | Max send buffers used during socket life: 3
2024-08-09 19:36:38.053 | DTC Client socket (3) | Max send buffer size during socket life: 628
2024-08-09 19:36:38.053 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:38.053 | Delayed Data Feed | Disconnected from the server.
2024-08-09 19:36:38.053 | Delayed Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:38.054 | DTC Client socket (1) | CloseSocket call.
2024-08-09 19:36:38.054 | Delayed Data Feed | Disconnected from the server.
2024-08-09 19:36:38.054 | Delayed Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:38.055 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:38.055 | DTC Client socket (2) | CloseSocket call.
2024-08-09 19:36:38.055 | Delayed Data Feed | Disconnected from the server.
2024-08-09 19:36:38.055 | SC Data - All Services | Disconnected.
2024-08-09 19:36:38.055 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:38.114 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-08-09 19:36:38.114 | DTC Client socket (3) | Closed.
2024-08-09 19:36:38.115 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-08-09 19:36:38.115 | DTC Client socket (2) | Closed.
2024-08-09 19:36:38.215 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-08-09 19:36:38.215 | DTC Client socket (1) | Closed.
2024-08-09 19:36:44.623 |
2024-08-09 19:36:44.624 | SC Data - All Services | Connected to server complete.
2024-08-09 19:36:44.629 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-08-09 19:36:44.651 | Mapping AQN to AQN. Service code: us_equities_utp_cta_exchange.data
2024-08-09 19:36:44.651 | Using symbol data fast lookup vector
2024-08-09 19:36:44.651 | Denali Data Feed | Starting real-time market data updates for: AQN (AQN). ID: 1 Service code: us_equities_utp_cta_exchange.data
2024-08-09 19:36:44.651 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10048
2024-08-09 19:36:44.653 | DTC Client socket (1) | Creating socket.
2024-08-09 19:36:44.653 | DTC Client socket (1) | New receive buffer size: 0
2024-08-09 19:36:44.653 | DTC Client socket (1) | Connecting to IP: 38.103.112.202.
2024-08-09 19:36:44.653 | Denali Data Feed | Requesting security definition data for: AQN (AQN). ID: 1
2024-08-09 19:36:44.704 | Denali Data Feed | Network connection to server complete.
2024-08-09 19:36:44.704 | Denali Data Feed | Starting socket receive thread.
2024-08-09 19:36:44.704 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-08-09 19:36:44.771 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-08-09 19:36:44.771 | Denali Data Feed | Sending logon request message.
2024-08-09 19:36:44.943 | Denali Data Feed | Received logon response.
2024-08-09 19:36:44.943 | Denali Data Feed | Server Name: RealTimeServer.
2024-08-09 19:36:44.943 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-08-09 19:36:44.943 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3
2024-08-09 19:36:44.943 | Denali Data Feed | Failed connections: 46
2024-08-09 19:36:44.943 | Denali Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:44.944 | DTC Client socket (1) | CloseSocket call.
2024-08-09 19:36:44.944 | Denali Data Feed | Disconnected from the server.
2024-08-09 19:36:44.944 | Denali Data Feed | Data feed disconnected. Will reconnect in 5 seconds.
2024-08-09 19:36:44.944 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:44.991 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-08-09 19:36:44.991 | DTC Client socket (1) | Closed.
2024-08-09 19:36:49.936 | Denali Data Feed | Connecting to the server ds33.sierracharts.com. Port 443
2024-08-09 19:36:49.937 | DTC Client socket (1) | Creating socket.
2024-08-09 19:36:49.937 | DTC Client socket (1) | New receive buffer size: 0
2024-08-09 19:36:49.937 | DTC Client socket (1) | Connecting to IP: 69.39.70.245.
2024-08-09 19:36:49.998 | Denali Data Feed | Network connection to server complete.
2024-08-09 19:36:49.998 | Denali Data Feed | Starting socket receive thread.
2024-08-09 19:36:49.998 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-08-09 19:36:50.073 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-08-09 19:36:50.073 | Denali Data Feed | Sending logon request message.
2024-08-09 19:36:50.260 | Denali Data Feed | Received logon response.
2024-08-09 19:36:50.260 | Denali Data Feed | Server Name: RealTimeServer.
2024-08-09 19:36:50.260 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-08-09 19:36:50.260 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3
2024-08-09 19:36:50.260 | Denali Data Feed | Failed connections: 47
2024-08-09 19:36:50.260 | Denali Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:50.261 | DTC Client socket (1) | CloseSocket call.
2024-08-09 19:36:50.261 | Denali Data Feed | Disconnected from the server.
2024-08-09 19:36:50.261 | Denali Data Feed | Data feed disconnected. Will reconnect in 5 seconds.
2024-08-09 19:36:50.261 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:50.320 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-08-09 19:36:50.320 | DTC Client socket (1) | Closed.
2024-08-09 19:36:55.273 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 443
2024-08-09 19:36:55.275 | DTC Client socket (1) | Creating socket.
2024-08-09 19:36:55.275 | DTC Client socket (1) | New receive buffer size: 0
2024-08-09 19:36:55.275 | DTC Client socket (1) | Connecting to IP: 38.103.112.179.
2024-08-09 19:36:55.326 | Denali Data Feed | Network connection to server complete.
2024-08-09 19:36:55.326 | Denali Data Feed | Starting socket receive thread.
2024-08-09 19:36:55.326 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-08-09 19:36:55.389 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-08-09 19:36:55.389 | Denali Data Feed | Sending logon request message.
2024-08-09 19:36:55.842 | Denali Data Feed | Received logon response.
2024-08-09 19:36:55.842 | Denali Data Feed | Server Name: RealTimeServer.
2024-08-09 19:36:55.842 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-08-09 19:36:55.842 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3
2024-08-09 19:36:55.842 | Denali Data Feed | Failed connections: 48
2024-08-09 19:36:55.842 | Denali Data Feed | Waiting for socket receive thread to end
2024-08-09 19:36:55.844 | DTC Client socket (1) | CloseSocket call.
2024-08-09 19:36:55.844 | Denali Data Feed | Disconnected from the server.
2024-08-09 19:36:55.844 | Denali Data Feed | Data feed disconnected. Will reconnect in 5 seconds.
2024-08-09 19:36:55.844 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-08-09 19:36:55.893 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-08-09 19:36:55.893 | DTC Client socket (1) | Closed.
2024-08-09 19:37:00.840 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10048
2024-08-09 19:37:00.841 | DTC Client socket (1) | Creating socket.
2024-08-09 19:37:00.841 | DTC Client socket (1) | New receive buffer size: 0
2024-08-09 19:37:00.841 | DTC Client socket (1) | Connecting to IP: 38.103.112.202.
2024-08-09 19:37:00.896 | Denali Data Feed | Network connection to server complete.
2024-08-09 19:37:00.896 | Denali Data Feed | Starting socket receive thread.
2024-08-09 19:37:00.896 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-08-09 19:37:00.959 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-08-09 19:37:00.959 | Denali Data Feed | Sending logon request message.
imageAQN chart.png / V - Attached On 2024-08-09 23:19:55 UTC - Size: 186.96 KB - 37 views
[2024-08-12 13:01:31]
The following in your log is the issue:
You are connected to the Denali Exchange Data Feed from 3 computers in total, but you are only setup to connect from 2 computers simultaneously. You need to exit Sierra Chart from the third computer.
