Date/Time: Sat, 23 Nov 2024 17:02:50 +0000
Sierra operated from a usb drive
View Count: 168
[2024-08-09 14:11:51]
User14953 - Posts: 235
Can this installation of Sierra which is operated from a usb drive
be configured so that newly named studies appear in alphabetical order
under the Analysis > Studies menu instead of at the end of the group?
When Analysis > Studies are modified and saved under a new name
the newly named study does not then appear in alphabetical order under the Analysis > Studies menu.
Instead it appears added to the end of the group.
[2024-08-09 15:06:37]
The list of Studies to Graph will never be in alphabetical order. The order of the studies in that are is important, as it controls the z-order of the drawings (what is drawn first and last, so what is on top of another) and the calculation order. Refer to the following and the section below it:
Chart Studies: Study Display Order
With regards to running Sierra Chart on a USB drive, although it is possible, it is not recommended. Mostly due to the access speed to the drive for data.
