Date/Time: Sat, 23 Nov 2024 17:05:51 +0000
Trade Activity Log- “Disabled”
View Count: 116
[2024-08-08 21:21:20] |
User228762 - Posts: 8 |
Hi, When I open my “Trade Activity Log” on Sierra Chart and filter for my trades it doesn’t bring up any trades and it says “disabled.” How do I fix this issue so that I can view my trades log. Thank you |
Private File |
[2024-08-08 23:34:46] |
On the Trade Activity Log select "Edit >> Disable Trade Activity Log". From what you state, this should have a checkmark next to it, meaning that it is disabled, selecting it again will disable the disable, hence it will be enabled. Also check the item just above it "Edit >> Disable Statistics, Trades, Periods Tabs" and make sure it does not have a checkmark next to it, if it does, then select it as well to remove the checkmark. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
