Date/Time: Sat, 23 Nov 2024 16:38:44 +0000
Lag Chart
View Count: 180
[2024-08-08 18:31:17]
livetotrade - Posts: 17
Hi, I don't know for some reason my /NQ charts is very lag, the other charts is fine. They are in different chartbooks.
Please advice. Thanks
attachmentNADRO_NQ.Cht - Attached On 2024-08-08 18:30:57 UTC - Size: 75.23 KB - 111 views
[2024-08-08 18:42:18]
specially the DMI TAB is very lag, eventhough i only use 30 day data load and only few indicators from sierra
[2024-08-08 20:47:38]
We do see the DMI chart being laggy in terms of responsiveness. In hiding and showing studies, we see that it is due to the Volume by Price studies. You should adjust the "Ticks per Volume" bar to something other than 1 in order to increase the responsiveness.
[2024-08-08 22:07:58]
Thank you switched it to 8 it solved the issued.
