Date/Time: Sat, 23 Nov 2024 13:00:29 +0000
Lumber(LBS) data not available
View Count: 177
[2024-08-08 18:10:14]
User815436 - Posts: 17
Hi, I was trying to load Lumber charts in Sierra but it says data not available. Please let me know if it is possible to trade it through Sierra.
Also, "LBSU24-LBSX24.LBS.FUT_SPREAD.CME" and the LBS outright contracts are getting traded with decent volume in CME.
[2024-08-09 17:17:06]
Sierra_Chart Engineering - Posts: 17145
We are checking on this.
We thought lumber was LBR not LBS.
Date Time Of Last Edit: 2024-08-09 17:17:41
[2024-08-13 13:41:57]
Any updates on this?
[2024-08-13 20:12:36]
For lumber this is what we see:
https://www.cmegroup.com/markets/agriculture/lumber-and-softs/lumber.contractSpecs.html
Do you have a link for the LBS contract on the CME website?
[2024-08-19 17:10:35]
Yes that is the product that I want to trade through Sierra. Its quoted as LBS in Sierra, but LBR in CME.
[2024-08-19 20:42:48]
The particular symbol depends on the service that your system is set to connect to. From what we can see, it looks like you are setup to connect to the Teton Order Routing Service, in which case the symbol is LBR - specifically the format is LBR?##_FUT_CME.
Why do you state that it is showing as LBS? If you use the "File >> Find Symbol" window, you will see it as LBR.
[2024-08-20 11:19:13]
My current setup is connected with TT Futures Order Routing not Teton Order Routing Service. And it is showing up as LBS (Lumber), please check the attached screenshot.
imagelbs lumber.png / V - Attached On 2024-08-20 11:18:53 UTC - Size: 12.86 KB - 32 views
[2024-08-21 01:08:11]
We have added the LBR lumber futures.
