Date/Time: Sat, 23 Nov 2024 16:40:48 +0000
[User Discussion] - Can More Than One Account be Connected to My Sierra/Denali/Teton Subscription, or
View Count: 100
[2024-08-08 18:04:34] |
User413206 - Posts: 26 |
Do I need to create another Sierra account, purchase another subscription, and have the broker connect it to my second brokerage account?
[2024-08-08 18:19:32] |
Sierra_Chart Engineering - Posts: 17150 |
You just need one Sierra Chart account. You can use it with multiple services. Refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
