Date/Time: Sat, 23 Nov 2024 16:41:03 +0000
Color Bar Alert with 4 variables
View Count: 118
[2024-08-08 17:08:01]
KXRCap - Posts: 64
SC -
What is the best practice for coloring a bar based on more then 2 variable (4 for is my goal). I need all 4 to be true to color the bar.
=AND(1<A,2<A,3>B,4>B) --- would be my example string of variables... but I believe =AND is only 2 variables.
K
[2024-08-08 18:42:11]
AND() is not limited to two variables. So the way you have described it (comma separated conditions) will work for what you want.
[2024-08-08 19:33:44]
KXRCap - Posts: 64
Ok, thanks, I must be getting something wrong then as I am not getting the outcome...
But will keep trying.
K
