Date/Time: Sat, 23 Nov 2024 17:04:38 +0000
Study Value is blocking the number bar calculated values
View Count: 122
[2024-08-08 16:24:02]
pennydoll9 - Posts: 20
SC Team, I am trying to get this right where I marked with a rectangle, the candle/number bar has already formed but the number bar calculated values do not show below, how can I fix this?
Thanks in advance!
imagesc_1.png / V - Attached On 2024-08-08 16:23:57 UTC - Size: 80.21 KB - 28 views
[2024-08-08 16:25:10]
You need to either move the labels to the left, or not overwrite the data with the labels. There are Inputs for these options on the Numbers Bars Calculated Values studies. Refer to the following:
Numbers Bars: Numbers Bars Calculated Values Input Descriptions
