Date/Time: Sat, 23 Nov 2024 16:54:48 +0000
Tradovate + TopStep account on top of existing data feed?
View Count: 188
[2024-08-08 01:31:39]
User790187 - Posts: 3
I currently have Denali Data feed (CME Market depth) with AMP Brokers using Teton routing. Everything is working great.
Now I would like to also trade my TopStep account which is with Tradeovate on Sierra Charts. Is it possible to add a tradovate account while keeping my current datafeeds?
[2024-08-08 14:33:37]
The first thing you need to be aware of is that you can not use Sierra Chart with Tradovate. This is a restriction on their end. You will need to use Rithmic for the order routing. Talk to TopStep about this.
Once you are setup with Rithmic for the order routing with TopStep, then you can use the Denali Exchange Data Feed for the data while trading with TopStep. This is not a problem. Refer to the following for more information on this:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
You will want to install a second Sierra Chart in order to have one installation connected to your Teton account and the other installation connected to TopStep. Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
As long as both installations are on the same computer, then there are no additional fees for this. If you need to use a second computer, then the exchanges require that you pay a second set of exchange fees. Refer to the following:
Denali Exchange Data Feed: Connections
