Date/Time: Sat, 23 Nov 2024 17:19:20 +0000
I am unable to connect to live data - Firm: IronBeam
View Count: 127
[2024-08-07 19:48:48]
User177805 - Posts: 2
I am unable to connect to live data, I am getting the following message
Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time.
I will appreciate if you can fix this issue.
Thank you!
Ahmed Lakhani
[2024-08-07 20:09:26]
We would like to see your entire Message Log by following these instructions:
But most likely this is an issue on your end. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
[2024-08-07 20:24:14]
Thank you for getting back to me but it started working again after I restarted my computer.
Thank you!!!
