Date/Time: Sat, 23 Nov 2024 17:28:44 +0000
TPO Chart Like Dalton
View Count: 157
[2024-08-07 18:49:50]
User131975 - Posts: 78
Hello, I have been using the TPO chart for a long time. Is there a way to display the value area with a transparent box like in the screenshot? I have already searched for solutions but none work
imageScreenshot 2024-08-07 204804.png / V - Attached On 2024-08-07 18:49:43 UTC - Size: 1.18 MB - 66 views
[2024-08-07 19:06:04]
Okay, I've managed it by having a second chart with the TPO lines, but isn't there a better solution?
[2024-08-07 19:15:56]
Bc now it lokks like this. The Overnight Inventory have it too and thats not what i need..
And the Boxes are way to wide and overlap the VP
Date Time Of Last Edit: 2024-08-07 19:16:21
imageScreenshot 2024-08-07 211518.png / V - Attached On 2024-08-07 19:15:37 UTC - Size: 106.75 KB - 57 views
[2024-08-07 20:07:09]
There is no direct option for doing what you are wanting, so what you have found is probably the best way.
