Date/Time: Sat, 23 Nov 2024 17:26:44 +0000
Live data
View Count: 102
[2024-08-07 14:01:09]
User572037 - Posts: 9
How do I check if I have live data showing on my charts please?
[2024-08-07 15:59:14]
You can customize the Chart Header and add an item named "Data Delay". This will show as "DD:" in the chart header followed by the amount of the delay. If you are getting delayed data for the CME Group, then this would show as 00:10:10, meaning 10 minutes and 10 seconds of delay. Other exchanges that are delayed would be 15 minutes. Refer to the following:
Global Settings Menu: Customize Chart Header - Standard (Global Settings menu)
Note that the actual amount you see may vary depending on how different your computer clock is from the standard. So if you see a few seconds, or even a few minutes, then this would imply that your computer clock is off. Refer to the following for ways to update your computer clock to match the standard:
Global Settings Menu: Set System Date-Time from Server (Global Settings menu)
Network Time Protocol Client
