Date/Time: Sat, 23 Nov 2024 16:39:25 +0000
Hide / Change color based on size displayed in DOM MARKET ORDERS columns
View Count: 165
[2024-08-07 13:32:12]
masedi - Posts: 40
Hi Support Team,
I am not able to find any setting to change color or hide market orders based on the size displayed in the market order column on the DOM window.
My goal essentially is to eliminate noise and only show (or change color) when the values exceed a certain threshold... similar to the setting on the setting passive orders:
Chart -> Chart Setting -> Chart DOM/DOM Graph: Only Display Market Depth Above/Equal Quantity (0=disabled):100
but for market orders column.
Would appreciate it if you could guide me.
imageScreenshot 2024-08-07 173050.png / V - Attached On 2024-08-07 13:31:19 UTC - Size: 143.38 KB - 37 views
[2024-08-07 15:52:37]
There is no setting for this. What you can do is adjust the minimum Market by Order quantity per symbol. Refer to the following:
Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data
