Date/Time: Sat, 23 Nov 2024 16:39:53 +0000
Numbers Bar chart automatically widens padding between rectangles
View Count: 117
[2024-08-07 10:40:52] |
User480109 - Posts: 36 |
For some reason on a Numbers bars chart (pls refer to attached pic), sometimes the padding will automatically widen between the bars(rectangles). What setting is it that to keep the spacing between bars always constant? Very annoying to see.
PaddingWidenExample.JPG / V - Attached On 2024-08-07 10:40:45 UTC - Size: 23.21 KB - 33 views |
[2024-08-07 15:29:41] |
That is a scaling issue. There is nothing you can do about it. You just have to adjust the vertical scale range to where the rectangles are aligned how you want them. Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
