Date/Time: Sat, 23 Nov 2024 16:57:42 +0000
MGC continuous contract - best settings?
View Count: 136
[2024-08-07 08:42:02]
User634406 - Posts: 36
Unlike indices, with their H,M,U,Z rollovers, GC has some months when the volume is low. Like V contract, where the next traded high-volume contract is Z.
So my current setting is "volume rollover", and it works well for indices. But in GC I got this bit of V contract trading which is then(based on volume)rolled over to Z in like 7 days, leaving gaps behind and a funny looking chart(the thin volume of the V contract is obvious if you use something like 5 min chart).
What are the best settings in this case?
Is it possible(and recommended) to somehow skip V and display only Q, followed by Z(basically just displaying the high volume contracts and back-adjusting it to make it right)?
[2024-08-07 09:34:08]
Sierra_Chart Engineering - Posts: 17150
There is a solution to this but it was not implemented for this symbol. It is now.
And then reload the chart with Chart >> Reload and Recalculate.
Make sure though that the MGC chart is not set to the V contract.
Date Time Of Last Edit: 2024-08-07 10:04:02
[2024-08-07 10:03:29]
Much better now. Thanks.
