Date/Time: Sat, 23 Nov 2024 17:08:21 +0000
[Programming Help] - Multiple chart windows in one detached chart window.
View Count: 117
[2024-08-07 04:00:48] |
aygh - Posts: 14 |
Is it possible to have 2 or more chart windows in one detached window? For reference I have attached a chart from ninjatrader. On this I can just switch between charts on the this window much like you can already do on the main Sierra Chart window with tabs.
Date Time Of Last Edit: 2024-08-07 04:01:43
[2024-08-07 14:59:42] |
There is not a way to do this in the way you are thinking. In other words, detached charts do not have the ability to group charts together. A detached chart exists on its own. A way to do this is to use a Sub-Instance of Sierra Chart, where you open another full instance of the software. In this case, you then can have the main window with multiple charts in it available as a separate window. Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
