Date/Time: Sat, 23 Nov 2024 16:55:50 +0000
Zig zag confirmed pivot point
View Count: 139
[2024-08-07 03:46:00]
User918104 - Posts: 4
I’ve set an alert on my zig zag but i keep getting alerts when the current leg expand. Is there a formula that would trigger the alert only when the new leg started, after pivot point is confirmed, not when still extending ongoing leg ?
Thanks for your help
[2024-08-07 14:46:14]
You need to use the "Zig Zag Oscillator" subgraph in order to do this. In this case, you need to check when the oscillator goes from Negative to Positive or Positive to Negative. The Alert condition would look like the following:
=OR(AND(ID1.SG9 > 0, ID1.SG9[-1] < 0), AND(ID1.SG9 > 0, ID1.SG9 < 0))
[2024-08-07 14:53:35]
Thanks a lot for your help John
