Date/Time: Sat, 23 Nov 2024 17:22:11 +0000
Historic Data Chart not compatible with Custom Symbol Settings
View Count: 106
[2024-08-07 02:35:23]
User_MD - Posts: 11
I want to filter Market by Order minimum quantities, and have set custom symbol settings as seen in the pic.
Unfortunately this prevents my historical chart (ES daily in this example) from loading each day's candle while set. If I select Edit > Download data for historical chart I get the error message in teh second pic.
I can deselect Set Custom Symbol and download the daily candle every day, then reset Custom to get my Market by Order data filter back, but this is cumbersome.
Is there an easier way?
imageUntitled.png / V - Attached On 2024-08-07 02:18:36 UTC - Size: 44.85 KB - 34 views
imageUntitled2.png / V - Attached On 2024-08-07 02:23:01 UTC - Size: 15.17 KB - 31 views
[2024-08-07 14:18:40]
Something else in the symbol settings for that symbol must have been changed that is causing this issue. Look through all the settings and see if there are any others that are not set to their default. They will have a asterisk in the middle column like the entry for "Minimum Market by Order Quantity" shows. Change anything that is not the default back to the default except the "Minimum Market by Order Quantity" (you can leave that one as it is).
