Date/Time: Sat, 23 Nov 2024 17:10:20 +0000
s_NumericInformationGraphDrawTypeConfig set subgraph's index background and set text bold
View Count: 158
[2024-08-06 16:33:43] |
User92573 - Posts: 530 |
Dear Support Many thanks for increasing the number of ACS Buttons to cover all 12 control bars. I've just started working with: s_NumericInformationGraphDrawTypeConfig
Is it possible to set the background and foreground for the cell which contains the heading. This is either the first or last, depending on whether aligned left/right? I've set the actual cells which contain data as described using: sc.CombinedForegroundBackgroundColorRef(COLOR_BLACK, COLOR_YELLOW) etc.
But I cant seem to set the header / descriptive cells background or it's text to Bold rather than just Normal. I have read through ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type and .h but could not find any settings.
Any help appreciated. Many thanks. |
[2024-08-06 17:35:29] |
The following items are available in the structure that will allow you to change the Labels text color: - bool DifferentPullbackAndLabelsColor - COLORREF PullbackAndLabelsColor But that is all that is available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-07 08:48:46] |
Hi John, If you have time would you briefly explain what a "Pullback" is. I can see "PullbackAndLabelsColor" etc. in ACSIL docs but can't work out what it is or what a Pullback Column is. Maybe its a coding term? Many thanks. Date Time Of Last Edit: 2024-08-07 08:49:46
[2024-08-07 15:22:27] |
Refer to the following: Chart Settings: Historical Pullback Data (Chart >> Chart Settings >> Chart Data >> Chart Data menu) And also the following and the other items related to the Pullback column in the Numbers Bars: Numbers Bars: Pullback Column # Numbers Bars Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
