Date/Time: Sat, 23 Nov 2024 17:30:08 +0000
Difference between symbols
View Count: 129
[2024-08-06 13:23:20]
Aczero - Posts: 11
So I bought the NASDAQ totalview and the consolidated tape. I also have package service 10
Which would you recommend for day trading equities? I added the NVDA, NVDA-MBO and NVDA-NQTV, and I have only noticed a volume difference but the speed is the same for all of them. Is there actually a difference between speed or anything? It seems like the MBO has the highest volume for every stock with it.
Another thing I noticed, sometimes the candlesticks or VWAP, or even the MAs can be different compared to tradingview. How exactly do I fix this? Which one is the most accurate?
Date Time Of Last Edit: 2024-08-06 13:27:05
[2024-08-06 15:25:59]
The data you use will depend on how you want to trade and perhaps what exchange you are doing your trading with. In the end, it is your personal decision on what works best for you.
Keep in mind the differences between the NASDAQ TotalView and the U.S. Equities Consolidated Tape data we have. The NASDAQ TotalView is just the price and volume data from the NASDAQ exchange. Whereas the U.S. Equities Consolidated Tape has the price and volume data from all the U.S. exchanges where an instrument is traded.
The MBO option is the price and volume data from the U.S. Equities Consolidated Tape along with the Market Depth data from the NASDAQ TotalView.
We can not help with comparisons against other systems. We stand behind our data and can tell you that it matches the exchange, as that is where it comes from.
