Date/Time: Sat, 23 Nov 2024 17:13:25 +0000
JSON parse error
View Count: 170
[2024-08-06 09:32:51]
User931541 - Posts: 17
Since this morning, I have been receiving the following error message when compiling (SC-Version 2666):
-- Starting remote build of Custom Studies Source files: Example_0110.cpp. 64-bit -- 11:21:09
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
JSON parse error: The document root must not be followed by other values.
-- End of Build -- 11:21:12
Until yesterday evening, everything was fine, and I haven't made any changes.
Could the problem be with Sierra Chart?
[2024-08-06 09:35:07]
Sierra_Chart Engineering - Posts: 17150
This is now resolved. However, you may need to run this command from the Windows Command Prompt:
ipconfig /flushdns
[2024-08-06 10:03:03]
Thanks for the info, everything is ok again (with flushdns).
