Date/Time: Sat, 23 Nov 2024 17:29:06 +0000
[Programming Help] - Can't Access Renko Bar Data that is in Chart #2 from Chart #1 in Chartbook.
View Count: 150
[2024-08-06 08:52:02]
User413206 - Posts: 26
I attempted refactor the code in the following example:
sc.GetChartBaseData()
But I can't get the values using the refactored code:
  // 1. Define a graph data object to get all of the base graph data from the secondary chart
  SCGraphData BaseGraphData;
  sc.GetChartBaseData(ChartStudy.GetChartNumber(), BaseGraphData);
  // 2. Create arrays for open and close prices from secondary chart.
  // - 2a. Get the Renko Open array from the secondary chart
  SCFloatArrayRef RenkoSecOpenArray = BaseGraphData[SC_OPEN];
  // - 2b. Get the Renko Close array from the secondary chart
  SCFloatArrayRef RenkoSecCloseArray = BaseGraphData[SC_CLOSE];
  // 3. Check if secondary array has enough bars.
  if (RenkoSecOpenArray.GetArraySize() < 2 || RenkoSecCloseArray.GetArraySize() < 2)
    sc.AddMessageToLog("Insufficient data in secondary chart arrays.", 1);
    return;
  // 5. Get the Renko open of second to last bar on secondary chart.
  float RenkoSecOpen2 = RenkoSecOpenArray[sc.ArraySize - 2];
  // 6. Get the Renko close of second to last bar on secondary chart.
  float RenkoSecClose2 = RenkoSecCloseArray[sc.ArraySize - 2];
  //DEBUG
  SCString Message;
  Message.Format("Bar Values: RenkoOpen=%f, RenkoClose=%f", RenkoSecOpen2, RenkoSecClose2);
  sc.AddMessageToLog(Message, 0);
The DEBUG message is showing:
2024-08-06 04:23:43.755 | Chart: CLU24[M] Flex Renko 5-3-2 #1 | Study: Renko Test | Bar Values: RenkoOpen=0.000000, RenkoClose=0.000000
[2024-08-06 10:25:26]
User431178 - Posts: 541
if you want to ghet the second last element from the other chart, you need to use
RenkoSecOpenArray.GetArraySize() - 2
not
sc.ArraySize - 2
sc.ArraySize applies only to the chart you are working from.
Also, Renko open and close are stored in SC_RENKO_OPEN and SC_RENKO_CLOSE
[2024-08-06 14:49:21]
Thanks for the GetArraySize() correction.
I forgot to change the code back to SC_RENKO_OPEN and SC_RENKO_CLOSE after testing whether it worked with SC_OPEN/SC_CLOSE.
Date Time Of Last Edit: 2024-08-06 14:50:06
