Date/Time: Sat, 23 Nov 2024 16:54:58 +0000
My Remote Builds are Failing with a JSON parse error.
View Count: 381
[2024-08-06 03:52:48] |
User413206 - Posts: 26 |
My builds stopped working all of the sudden. Build output: -- Starting remote build of Custom Studies Source files: HA.cpp. 64-bit -- 23:50:53 Allow time for the server to compile the files and build the DLL. Server: https://build.sierrachart.com JSON parse error: The document root must not be followed by other values. -- End of Build -- 23:50:54 |
[2024-08-06 04:02:58] |
TriStar Trading - Posts: 142 |
Same here v2666. Just started
[2024-08-06 04:05:12] |
Thanks for that. I'm on Version 2661. So, the version probably isn't the problem.
[2024-08-06 04:21:00] |
User156100 - Posts: 1 |
Same for me. v2666.
[2024-08-06 06:03:20] |
As a workaround, I installed Visual Studio Community Edition.
[2024-08-06 08:04:09] |
User189129 - Posts: 2 |
me too.
[2024-08-06 09:09:38] |
User357489 - Posts: 72 |
omg same! thought i was going insane- does any have a workaround that works? :) also im a novice study developer, can i pick someones brains please reg an auto trading system ive put together? please reach out on discord i would be forever grateful! campanariskman |
[2024-08-06 09:19:04] |
Sierra_Chart Engineering - Posts: 17150 |
We are checking on this.
[2024-08-06 09:25:14] |
This is now resolved. However you may need to go to the Windows command line (Like powershell) and run this command: ipconfig /flushDNS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-06 09:28:30] |
i run ipconfig /flushDNS and get: ipconfig : The term 'ipconfig' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again. At line:1 char:1 + ipconfig /flushDNS + ~~~~~~~~ + CategoryInfo : ObjectNotFound: (ipconfig:String) [], CommandNotFoundException + FullyQualifiedErrorId : CommandNotFoundException still learning so help appreciated |
[2024-08-06 09:30:57] |
belay that, working! TY |
[2024-08-06 09:33:17] |
Ok if you are having trouble running that command, then use Windows Command Prompt. It should work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
