Date/Time: Sat, 23 Nov 2024 17:05:09 +0000
How to change the width of the DOM
View Count: 122
[2024-08-05 23:52:15] |
User643426 - Posts: 127 |
How do I change the width of the DOM and the width of the chart trading window? It takes up too much space on my laptop and I can see my positions on the DOM.
[2024-08-06 14:19:05] |
You can not change the width of the Price Ladder itself, that is automatically set. But to change the widths of other columns in the DOM, refer to the following: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) The Trade Window size can not be changed. Most of the functionality of the Trade Window is now available within the Control Bars, so you can create a control bar and set it up as you want to replicate the Trade Window. This should take up less space. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
