Date/Time: Sat, 23 Nov 2024 18:15:20 +0000
Real-time market data only supported
View Count: 111
[2024-08-05 17:48:56]
oliviermo75 - Posts: 19
Hi
when i connect to data feed i get the message ( see the attached file ) .
However when i go and check in chart settings -> symbol ( Action ) : value F.US.DBU24
I'm trading on Eurex
sieera chart infos:
version 2568 64-bit
revision read only : 48235
thank you for your help
regards
oliver
imageReal-time-market.png / V - Attached On 2024-08-05 17:44:36 UTC - Size: 5.55 KB - 36 views
[2024-08-05 18:21:20]
You are connecting to CQG, and we do not have support for data from CQG for The CME Group and EUREX.
You would need to get these data from our Denali Exchange Data Feed. For EUREX, follow the instructions at the following link:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
