Date/Time: Sat, 23 Nov 2024 17:26:23 +0000
My child stop loss order didn't trigger
View Count: 231
[2024-08-05 17:06:59] |
ninnh51 - Posts: 8 |
Hello I had an overnight orders for ES and NQ with set stop loss. somehow the child stop loss order didn't trigger overnight and i took a massive loss. This happened 2 sunday's ago as well. Why is this keep happening? this is very inconsistent performance of the software. What could have i done differently? |
[2024-08-05 17:08:30] |
You need to look at the "Trade Activity Log" and see why the Stop was removed. Refer to the following: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order Most likely, you had the "Time in Force" set to "Day", therefore the Stop would have been removed at the end of the trading day and not been present overnight. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-05 17:13:26] |
Thanks, how do i check the time settings? it's been a brutal loss and completely wiped my account out. anyhelp you can offer is appreciated.
[2024-08-05 18:18:57] |
For attached accounts, you can view what you have set for new orders by referring to the following: Attached Orders: Time In Force For an already placed order, you would need to find the order on your Trade Activity Log in the "Trade Activity" page and scroll to the right where there is a column for "Time in Force" and see what was the value for that particular order. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-06 15:54:42] |
Thanks John, appreciate it. something is not making sense. Please see attached screenshot. it says CQG fills data restored and it didn't have child orders listed there.
Attachment Deleted. Private File |
[2024-08-06 22:00:20] |
Sierra_Chart Engineering - Posts: 17150 |
This is usually the result of two things. 1. Not using Good till Canceled for the Attached Orders for the Time in Force: Attached Orders: Time In Force 2. Or in your case because you are using CQG, if the parent order has not yet filled and Sierra Chart is not running or there is a loss of connectivity, then the child orders will not be sent to the exchange. This is why we strongly recommend using Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-06 22:00:58
[2024-08-07 13:55:39] |
Thanks John, appreciate the response, i will try to switch to teton. i have a quick favor to ask, when i hit "flatten" button, it cancels the child orders. do you know what's causing that? I have to hit "flatten" twice to get out of the trade. 2024-08-02 17:28:59.729 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-02, . MostRecentFileNameSearched: TradeActivityLog_2024-08-02_UTC.180844.data. DuplicateRecordsRemovedCount: 78. OriginalRecordsToInsertCount: 78. RecordsToInsertCount: 0 2024-08-02 17:28:59.729 | TradeActivity files query time: 0.043501 seconds. Entries: 0. Current queries: 1 2024-08-02 17:29:06.953 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-02 17:29:06.953 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-02 17:29:07.019 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-02 17:29:07.019 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-02 17:29:07.273 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-02 17:29:07.273 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-02 17:29:09.637 | TradeActivity files query time: 0.025879 seconds. Entries: 0. Current queries: 1 2024-08-02 18:03:17.131 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-02 18:03:17.131 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-02 18:03:17.765 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-02 18:03:17.765 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-04 09:13:39.926 | CQG WebAPI | User message | Log: No response to server ping request sent 30 seconds ago. | Source: Web API Server 2024-08-04 09:14:15.614 | TradeActivity files query time: 29.902583 seconds. Entries: 0. Current queries: 5 2024-08-04 09:14:15.643 | TradeActivity files query time: 0.029000 seconds. Entries: 169. Current queries: 5 2024-08-04 09:14:15.665 | TradeActivity files query time: 0.021379 seconds. Entries: 0. Current queries: 5 2024-08-04 09:14:15.716 | TradeActivity files query time: 0.051074 seconds. Entries: 132. Current queries: 5 2024-08-04 09:14:46.240 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 09:14:46.240 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-04 09:14:49.121 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 09:14:49.121 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-04 09:14:49.121 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 09:14:49.121 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-04 09:14:50.143 | TradeActivity files query time: 34.427152 seconds. Entries: 0. Current queries: 1 2024-08-04 09:15:13.964 | TradeActivity files query time: 0.054544 seconds. Entries: 132. Current queries: 1 2024-08-04 09:15:31.746 | TradeActivity files query time: 0.136960 seconds. Entries: 0. Current queries: 1 2024-08-04 09:15:33.266 | TradeActivity files query time: 0.100262 seconds. Entries: 0. Current queries: 1 2024-08-04 09:16:01.252 | TradeActivity files query time: 0.034320 seconds. Entries: 132. Current queries: 1 2024-08-04 09:16:13.254 | TradeActivity files query time: 0.047011 seconds. Entries: 169. Current queries: 1 2024-08-04 09:16:29.781 | TradeActivity files query time: 0.031639 seconds. Entries: 0. Current queries: 1 2024-08-04 09:16:37.589 | TradeActivity files query time: 0.032844 seconds. Entries: 0. Current queries: 1 2024-08-04 09:17:30.612 | TradeActivity files query time: 0.107254 seconds. Entries: 169. Current queries: 1 2024-08-04 12:36:00.573 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 12:36:00.573 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-04 12:36:04.698 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 12:36:04.698 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-04 12:36:06.780 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 12:36:06.780 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-04 17:23:38.290 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 17:23:38.290 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-04 17:23:46.073 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 17:23:46.073 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-04 17:23:46.280 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 17:23:46.280 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-04 17:23:46.392 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-04 17:23:46.392 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-04 18:31:10.659 | Order modification failed (InternalOrderID) | Unable to modify order because it is no longer working. Internal Order ID: 5171. Service Order ID: 581065355. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-05 08:03:09.715 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 08:03:09.715 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 08:03:11.230 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 08:03:11.230 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 08:03:12.918 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 08:03:12.918 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 08:03:13.455 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 08:03:13.456 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 08:03:13.469 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-04, 2024-08-05, . MostRecentFileNameSearched: TradeActivityLog_2024-08-05_UTC.None.data. DuplicateRecordsRemovedCount: 18. OriginalRecordsToInsertCount: 22. RecordsToInsertCount: 4 2024-08-05 08:03:13.469 | TradeActivity files query time: 0.085243 seconds. Entries: 0. Current queries: 1 2024-08-05 08:03:13.783 | TradeActivity files query time: 0.161172 seconds. Entries: 140. Current queries: 1 2024-08-05 08:03:14.590 | TradeActivity files query time: 0.051798 seconds. Entries: 183. Current queries: 1 2024-08-05 08:09:21.807 | TradeActivity files query time: 1.212888 seconds. Entries: 0. Current queries: 2 2024-08-05 08:09:21.814 | TradeActivity files query time: 0.006791 seconds. Entries: 0. Current queries: 2 2024-08-05 08:09:50.799 | TradeActivity files query time: 0.000884 seconds. Entries: 0. Current queries: 1 2024-08-05 08:09:51.829 | TradeActivity files query time: 0.001152 seconds. Entries: 0. Current queries: 1 2024-08-05 08:10:08.042 | TradeActivity files query time: 0.004662 seconds. Entries: 22. Current queries: 1 2024-08-05 08:10:09.617 | TradeActivity files query time: 0.006830 seconds. Entries: 22. Current queries: 1 2024-08-05 08:22:59.918 | TradeActivity files query time: 0.078690 seconds. Entries: 0. Current queries: 1 2024-08-05 08:23:12.456 | TradeActivity files query time: 0.115050 seconds. Entries: 0. Current queries: 1 2024-08-05 08:23:21.815 | TradeActivity files query time: 0.157053 seconds. Entries: 0. Current queries: 1 2024-08-05 10:29:06.112 | Trade Order Error - CQG order update. Status: REJECTED. Text: Daily loss limit has been reached. Loss limit (based on cash and collateral only) = USD884.94, actual current loss = USD886.75. Internal Order ID: 5188. Service Order ID: 582937149. Symbol: F.US.MESU24. Account: 180844 * 2024-08-05 10:29:06.114 | Trade Order Error - CQG order update. Status: REJECTED. Text: Daily loss limit has been reached. Loss limit (based on cash and collateral only) = USD884.94, actual current loss = USD886.75. Internal Order ID: 5189. Service Order ID: 582937150. Symbol: F.US.MESU24. Account: 180844 * 2024-08-05 10:47:53.386 | Trade Order Error - CQG order update. Status: REJECTED. Text: Daily loss limit has been reached. Loss limit (based on cash and collateral only) = USD884.94, actual current loss = USD886.75. Internal Order ID: 5195. Service Order ID: 582963300. Symbol: F.US.MESU24. Account: 180844 * 2024-08-05 10:47:53.386 | Trade Order Error - CQG order update. Status: REJECTED. Text: Daily loss limit has been reached. Loss limit (based on cash and collateral only) = USD884.94, actual current loss = USD886.75. Internal Order ID: 5196. Service Order ID: 582963301. Symbol: F.US.MESU24. Account: 180844 * 2024-08-05 10:53:43.646 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 10:53:43.647 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 10:55:15.623 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 10:55:15.623 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 11:28:52.691 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 11:28:52.691 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 11:28:53.516 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 11:28:53.516 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 11:28:53.530 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 11:28:53.530 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 11:28:57.709 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 11:28:57.709 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 11:28:58.515 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-04, 2024-08-05, . MostRecentFileNameSearched: TradeActivityLog_2024-08-05_UTC.180844.data. DuplicateRecordsRemovedCount: 26. OriginalRecordsToInsertCount: 26. RecordsToInsertCount: 0 2024-08-05 11:28:58.515 | TradeActivity files query time: 0.099516 seconds. Entries: 0. Current queries: 1 2024-08-05 11:28:58.775 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 11:28:58.775 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 13:11:44.469 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 13:11:44.470 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 13:11:51.747 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 13:11:51.747 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 13:11:54.431 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-04, 2024-08-05, . MostRecentFileNameSearched: TradeActivityLog_2024-08-05_UTC.180844.data. DuplicateRecordsRemovedCount: 26. OriginalRecordsToInsertCount: 26. RecordsToInsertCount: 0 2024-08-05 13:11:54.431 | TradeActivity files query time: 0.059133 seconds. Entries: 0. Current queries: 1 2024-08-05 13:12:13.395 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 13:12:13.395 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 13:12:16.180 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 13:12:16.180 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-05 14:11:15.237 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 14:11:15.237 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 14:11:19.595 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 14:11:19.595 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-05 14:11:20.248 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-04, 2024-08-05, . MostRecentFileNameSearched: TradeActivityLog_2024-08-05_UTC.180844.data. DuplicateRecordsRemovedCount: 26. OriginalRecordsToInsertCount: 26. RecordsToInsertCount: 0 2024-08-05 14:11:20.248 | TradeActivity files query time: 0.056454 seconds. Entries: 0. Current queries: 1 2024-08-05 14:11:40.652 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-05 14:11:40.652 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 10:12:38.566 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 10:12:38.566 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-06 10:12:38.566 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 10:12:38.566 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 10:12:38.566 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 10:12:38.566 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 10:12:42.576 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 10:12:42.576 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-06 10:12:46.097 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 10:12:46.097 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 11:03:24.111 | Trade Order Error - CQG order update. Status: REJECTED. Text: Account purchasing power USD347 is insufficient to satisfy total portfolio margin requirement including this order USD400. Internal Order ID: 5246. Service Order ID: 585135969. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-06 11:47:00.565 | F.US.EPU24/F.US.MESU24[M] #10 | User order entry | Unable to Flatten/Reverse. Position does not exist | Symbol: F.US.MESU24 | TradeAccount: 180844 * 2024-08-06 11:47:01.693 | TradeActivity files query time: 1.263709 seconds. Entries: 0. Current queries: 2 2024-08-06 11:47:01.698 | TradeActivity files query time: 0.004563 seconds. Entries: 69. Current queries: 2 2024-08-06 11:48:27.874 | TradeActivity files query time: 0.323479 seconds. Entries: 0. Current queries: 2 2024-08-06 11:48:27.877 | TradeActivity files query time: 0.003585 seconds. Entries: 69. Current queries: 2 2024-08-06 11:58:39.299 | Order Modification Error: F.US.EPU24/F.US.MESU24[M] #10 | User order modification ignored. New price is the same during a price modify. Internal Order ID: 5274. Service Order ID: 585238317. Account: 180844 2024-08-06 14:04:46.627 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 14:04:46.627 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 14:04:49.301 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 14:04:49.301 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-06 14:04:49.305 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 14:04:49.305 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 14:04:49.306 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-06 14:04:49.306 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-06 14:04:51.332 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-06, . MostRecentFileNameSearched: TradeActivityLog_2024-08-06_UTC.180844.data. DuplicateRecordsRemovedCount: 49. OriginalRecordsToInsertCount: 49. RecordsToInsertCount: 0 2024-08-06 14:04:51.333 | TradeActivity files query time: 0.155705 seconds. Entries: 0. Current queries: 1 2024-08-06 14:52:14.235 | Order modification failed | Reject text: Buy order stop price must be above last trade price ExchangeRejectCode = 2061. Internal Order ID: 5311. Service Order ID: 585667157. Symbol: F.US.MESU24. Account: 180844 * 2024-08-06 15:51:28.691 | Order modification failed (InternalOrderID) | Unable to modify order because it is no longer working. Internal Order ID: 5357. Service Order ID: 585714127. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-06 15:56:42.594 | TradeActivity files query time: 1.888352 seconds. Entries: 0. Current queries: 2 2024-08-06 15:56:42.602 | TradeActivity files query time: 0.007093 seconds. Entries: 127. Current queries: 2 2024-08-06 15:56:53.976 | TradeActivity files query time: 0.019583 seconds. Entries: 127. Current queries: 1 2024-08-06 15:57:17.366 | TradeActivity files query time: 0.018347 seconds. Entries: 101. Current queries: 1 2024-08-06 15:57:18.153 | TradeActivity files query time: 0.029710 seconds. Entries: 101. Current queries: 1 2024-08-06 16:03:54.176 | Trade Order Error - CQG order update. Status: REJECTED. Text: No margin available after satisfying existing position margin (if any). Available margin = USD189, portfolio margin = USD200. Internal Order ID: 5368. Service Order ID: 585960280. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-06 16:03:54.176 | Trade Order Error - CQG order update. Status: REJECTED. Text: No margin available after satisfying existing position margin (if any). Available margin = USD189, portfolio margin = USD200. Internal Order ID: 5369. Service Order ID: 585960281. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-06 16:34:33.602 | Trade Order Error - CQG order update. Status: REJECTED. Text: Account purchasing power USD127 is insufficient to satisfy total portfolio margin requirement including this order USD200. Internal Order ID: 5389. Service Order ID: 585729756. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-06 17:56:04.932 | TradeActivity files query time: 0.596609 seconds. Entries: 0. Current queries: 2 2024-08-06 17:56:04.949 | TradeActivity files query time: 0.016321 seconds. Entries: 117. Current queries: 2 2024-08-06 17:56:17.003 | TradeActivity files query time: 0.019310 seconds. Entries: 117. Current queries: 1 2024-08-07 08:29:27.821 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-07 08:29:27.821 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-07 08:29:28.929 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-07 08:29:28.929 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-07 08:29:33.706 | Denali Data Feed | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 2024-08-07 08:29:33.706 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 2024-08-07 08:29:35.135 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-08-07 08:29:35.135 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-08-07 08:29:40.242 | RemoveDuplicateFillActivity | TradeAccount: . DatesOfRecordsToInsert: 2024-08-06, . MostRecentFileNameSearched: TradeActivityLog_2024-08-06_UTC.180844.data. DuplicateRecordsRemovedCount: 2. OriginalRecordsToInsertCount: 2. RecordsToInsertCount: 0 2024-08-07 08:29:40.242 | TradeActivity files query time: 0.072451 seconds. Entries: 0. Current queries: 1 2024-08-07 08:51:48.666 | Order Modification Error: F.US.EPU24/F.US.MESU24[M] #10 | User order modification ignored. New price is the same during a price modify. Internal Order ID: 5396. Service Order ID: 586417675. Account: 180844 2024-08-07 09:33:14.692 | Trade Order Error - CQG order update. Status: REJECTED. Text: Account purchasing power USD115 is insufficient to satisfy total portfolio margin requirement including this order USD200. Internal Order ID: 5407. Service Order ID: 586418928. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-07 09:38:21.250 | Trade Order Error - CQG order update. Status: REJECTED. Text: Account purchasing power USD123 is insufficient to satisfy total portfolio margin requirement including this order USD140. Internal Order ID: 5415. Service Order ID: 586600405. Symbol: F.US.MESU24. Account: 180844 * 2024-08-07 09:41:15.076 | Trade Order Error - CQG order update. Status: REJECTED. Text: Account purchasing power USD123 is insufficient to satisfy total portfolio margin requirement including this order USD200. Internal Order ID: 5418. Service Order ID: 586419790. Symbol: F.US.MNQU24. Account: 180844 * 2024-08-07 09:42:18.165 | F.US.ENQU24/F.US.MNQU24[M] #14 | User order entry | Unable to Flatten/Reverse. Position does not exist | Symbol: F.US.MNQU24 | TradeAccount: 180844 * 2024-08-07 09:47:37.232 | Trade Order Error - CQG order update. Status: REJECTED. Text: Account purchasing power USD175 is insufficient to satisfy total portfolio margin requirement including this order USD200. Internal Order ID: 5423. Service Order ID: 586513158. Symbol: F.US.MNQU24. Account: 180844 * |
[2024-08-07 14:31:51] |
You will not have this problem at all with Teton order routing. Teton is very different in its risk management compared to CQG and is superior. Teton has superior risk management as compared to CQG. It is far more advanced. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-07 14:32:05
[2024-08-07 14:57:48] |
ok thanks
