Date/Time: Sat, 23 Nov 2024 17:47:39 +0000
Removing the Large Dom
View Count: 117
[2024-08-05 16:36:45] |
User627105 - Posts: 5 |
Hi support, When I am playback testing I have a very large red / green dom list. How do I remove this? As when normally trading I just have 1 of each. Thanks User |
Screenshot 2024-08-05 173512.png / V - Attached On 2024-08-05 16:35:20 UTC - Size: 62.95 KB - 34 views Attachment Deleted. |
[2024-08-05 18:11:38] |
You must have downloaded the Market Depth data for the time period that you are replaying, which is why those are there. But as you note, you are not setup to get the Market Depth data in real-time. If you only want to view the 1 level in the DOM during a replay, then set the following setting to 1: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
