Date/Time: Sat, 23 Nov 2024 18:13:44 +0000
Continuous Futures Contract Data Missing
View Count: 129
[2024-08-05 16:28:54]
MarketBeast - Posts: 26
I'm using a 240 minute intraday chart with 365 days worth of data and using the continuous futures rollover in chart settings. For some reason I'm not able to see the price and volume data please see here https://prnt.sc/LIwoHitc5NlU
I have configured everything based on this doc Continuous Futures Contract Charts: Continuous Futures Contract - Volume Based Rollover, Back Adjusted
and have deleted and redownloaded the data but no luck in viewing the historic volume.
Here is the screenshot of my chart settings https://prnt.sc/PEMgpFBU8OtK
Also I wanted to ask if I uncheck this option https://prnt.sc/_TVkDckw8U8u to be able to use the continuous contract properly does that also mean I can not use custom value to filter "Market by order"?
Looking forward to hear from you.
Thank You!
[2024-08-05 16:30:55]
You are getting the Volume data, it is just much smaller for that time period in comparison to the more recent data. Hence the bars are simply not very tall.
If you uncheck the option for "Use Custom Symbol Settings Values", then you will not have the "Minimum Market by Order Quantity" setting having any affect.
