Date/Time: Sat, 23 Nov 2024 17:46:16 +0000
Numbers chart is blank
View Count: 87
[2024-08-05 15:05:58]
User8135477 - Posts: 115
I've tried to set up a numbers chart for the first time. I followed the instructions. My indicators (moving averages, time zone) are still showing on the chart, but there are no numbers bars.
Please let me know how I can troubleshoot.
[2024-08-05 15:43:34]
You are on the "Integrated Standard" package, therefore you do not have access to the Numbers Bars study. Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Integrated Packages
Follow these instructions if you want to change your package:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
