Date/Time: Sat, 23 Nov 2024 18:13:21 +0000
AMP
View Count: 173
[2024-08-05 12:57:12] |
User904434 - Posts: 54 |
I can not connect to AMP (CQG) - pls check
[2024-08-05 13:09:41] |
Sierra_Chart Engineering - Posts: 17150 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-05 13:12:03] |
2024-08-05 13:29:59.173 | Trade activity files set size: 1644 2024-08-05 13:29:59.314 | Created the DTC Protocol server. 2024-08-05 13:29:59.316 | DTC Protocol Server listening on port 11099. 2024-08-05 13:29:59.316 | Reading Internal Order ID file. 2024-08-05 13:29:59.319 | Reading Trade Orders file. 2024-08-05 13:29:59.319 | Reading Trade Positions file. 2024-08-05 13:29:59.319 | Reading Trade Account Data files. 2024-08-05 13:29:59.323 | UDPListener (1784). Port 22904 | Listening on UDP port 22904. 2024-08-05 13:29:59.323 | Software version: 2661 64-bit 2024-08-05 13:29:59.323 | Primary Thread ID: 18448 2024-08-05 13:29:59.323 | Usage end date: 2024-08-15 2024-08-05 13:29:59.323 | Enabled for: Advanced Features 2. 2024-08-05 13:29:59.323 | Enabled for: Sierra Chart Historical Data Service. 2024-08-05 13:29:59.323 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-08-05 13:29:59.323 | Enabled for: Delayed Denali Exchange Data Feed. 2024-08-05 13:29:59.323 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-08-05 13:29:59.323 | Current selected Data/Trading service: CQG WebAPI 2024-08-05 13:29:59.323 | Custom symbol settings values: enabled 2024-08-05 13:29:59.323 | Chart Update Interval: 500 2024-08-05 13:29:59.323 | Intraday Data Storage Time Unit: 0 2024-08-05 13:29:59.323 | Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) 2024-08-05 13:29:59.323 | 2024-08-05 12:29:59 Local computer time in UTC 2024-08-05 13:29:59.323 | 2024-08-05 13:29:59 Local computer time in SC Time Zone 2024-08-05 13:29:59.323 | 2024-08-05 12:29:42 Server time in UTC 2024-08-05 13:29:59.323 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-08-05 13:29:59.323 | Program path: C:\SierraChart\ 2024-08-05 13:29:59.323 | Data Files path: C:\SierraChart\Data\ 2024-08-05 13:29:59.323 | OS Version Number: 10.0 2024-08-05 13:29:59.323 | Locale Setting: C 2024-08-05 13:29:59.324 | DLLs: tickdeltavolume_64.dll, UserContributedStudies_64.dll, VolumebyJacek_64.dll 2024-08-05 13:29:59.324 | Allowed protected custom studies: 2024-08-05 13:29:59.324 | Crash reporter started: true 2024-08-05 13:29:59.324 | 2024-08-05 13:29:59.351 | Created the DTC Protocol historical data server. 2024-08-05 13:29:59.352 | HD Server Manager | Listening on port 11098. 2024-08-05 13:29:59.353 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. 2024-08-05 13:29:59.506 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-08-05 13:29:59.693 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-08-05 13:29:59.693 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-08-05 13:30:00.114 | Received 5 login tokens. 2024-08-05 13:30:01.174 | Symbol settings MD5 received. Request ID: 1. 2024-08-05 13:30:01.174 | Symbol settings are up-to-date for cqg. 2024-08-05 13:30:01.863 | Requested user files to download. 2024-08-05 13:30:03.851 | 2024-08-05 13:30:03.851 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 13:30:03.851 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 13:30:03.853 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-05 13:30:03.853 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-05 13:30:03.853 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-05 13:30:03.922 | CQG WebSocket | Opening WebSocket. 2024-08-05 13:30:03.922 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 13:30:04.121 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 13:30:04.121 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 13:30:04.121 | CQG WebSocket | Server header | Sec-WebSocket-Accept: ujYmTGRY3NeoIr5IEgqJSqdkocs= 2024-08-05 13:30:04.121 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 13:30:04.121 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 13:30:04.121 | CQG WebSocket | Server header | 2024-08-05 13:30:04.121 | CQG WebSocket | Web socket state is now open. 2024-08-05 13:30:04.121 | CQG WebAPI | WebSocket connected. 2024-08-05 13:30:04.121 | CQG WebAPI | Sending market data logon message. 2024-08-05 13:30:04.401 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 13:30:04.401 | CQG WebAPI | Logon successful. Session Token = 3nUs5YchBer9qTgF94YJmUZyFGbJJqvn+XHF5p79TVw124AcpjcfMsO0sy8AKGrJxvi616YhRKs 2024-08-05 13:30:04.401 | CQG WebAPI | Connected to server complete. 2024-08-05 13:30:04.402 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 13:30:04.402 | Updated verified funded futures trading account ending date to: 2024-09-04 12:30:04 2024-08-05 13:30:04.402 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 13:30:04.563 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 13:30:04.563 | Updated verified funded futures trading account ending date to: 2024-09-04 12:30:04 2024-08-05 13:30:04.563 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 13:30:04.653 | CQG WebAPI | Sending positions subscribe request. RequestID: 14087 2024-08-05 13:30:04.653 | CQG WebAPI | Sending orders subscribe request. RequestID: 14088 2024-08-05 13:30:24.574 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2024-08-05 13:30:25.535 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2024-09-04"}. Success=true 2024-08-05 13:30:26.226 | F.US.EPU24 #8 | Reloading chart. 2024-08-05 13:30:26.258 | F.US.EPU24 5 Min #3 | Reloading chart. 2024-08-05 13:30:26.511 | F.US.EPU24 #4 | Reloading chart. 2024-08-05 13:30:26.531 | F.US.EPU24 5 Min #5 | Reloading chart. 2024-08-05 13:30:26.535 | Loading market depth data. 2024-08-05 13:30:26.549 | F.US.EPU24 3.75 Range #7 | Reloading chart. 2024-08-05 13:30:26.553 | Loading market depth data. 2024-08-05 13:30:26.566 | F.US.EPU24 30 Min #6 | Reloading chart. 2024-08-05 13:30:26.580 | F.US.EPU24 20000 Volume #10 | Reloading chart. 2024-08-05 13:30:26.793 | F.US.EPU24 30 Min #1 | Reloading chart. 2024-08-05 13:30:26.800 | Loading market depth data. 2024-08-05 13:30:27.012 | F.US.EPU24 5 Min #2 | Reloading chart. 2024-08-05 13:30:27.018 | Loading market depth data. 2024-08-05 13:30:27.235 | F.US.EPU24 1 Min #11 | Reloading chart. 2024-08-05 13:30:27.240 | Loading market depth data. 2024-08-05 13:30:27.310 | Loading DLL: C:\SierraChart\Data\tickdeltavolume.dll (tickdeltavolume_64.dll). Handle: 66000000 2024-08-05 13:30:27.546 | F.US.EPU24 1 Sec #12 | Reloading chart. 2024-08-05 13:30:27.552 | Loading market depth data. 2024-08-05 13:30:27.620 | F.US.EPU24 #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.624 | F.US.EPU24 #8 | Chart data loading complete. 2024-08-05 13:30:27.626 | F.US.EPU24 5 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.626 | F.US.EPU24 5 Min #3 | Chart data loading complete. 2024-08-05 13:30:27.629 | F.US.EPU24 #4 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:30:27.630 | F.US.EPU24 #4 | Chart data loading complete. 2024-08-05 13:30:27.634 | F.US.EPU24 5 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.636 | F.US.EPU24 5 Min #5 | Chart data loading complete. 2024-08-05 13:30:27.637 | F.US.EPU24 3.75 Range #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.638 | F.US.EPU24 3.75 Range #7 | Chart data loading complete. 2024-08-05 13:30:27.639 | F.US.EPU24 30 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.640 | F.US.EPU24 30 Min #6 | Chart data loading complete. 2024-08-05 13:30:27.642 | F.US.EPU24 20000 Volume #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.642 | F.US.EPU24 20000 Volume #10 | Chart data loading complete. 2024-08-05 13:30:27.646 | F.US.EPU24 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.646 | F.US.EPU24 30 Min #1 | Chart data loading complete. 2024-08-05 13:30:27.649 | F.US.EPU24 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.649 | F.US.EPU24 5 Min #2 | Chart data loading complete. 2024-08-05 13:30:27.652 | F.US.EPU24 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.652 | F.US.EPU24 1 Min #11 | Chart data loading complete. 2024-08-05 13:30:27.654 | F.US.EPU24 1 Sec #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:30:27.654 | F.US.EPU24 1 Sec #12 | Chart data loading complete. 2024-08-05 13:30:27.765 | Using symbol data fast lookup vector 2024-08-05 13:30:27.765 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 13:30:27.765 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 13:30:27.765 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 13:30:27.765 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 13:30:27.765 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 13:30:27.765 | Intraday chart data file opened for F.US.EPU24 2024-08-05 13:30:27.771 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 13:30:27.771 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 13:39:37.023 | File >> Reconnect selected. 2024-08-05 13:39:37.023 | CQG WebAPI | Sending Web API Logoff message. 2024-08-05 13:39:37.023 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-05 13:39:37.023 | CQG WebSocket | WebSocket closed. 2024-08-05 13:39:37.023 | CQG WebAPI | WebSocket closed. 2024-08-05 13:39:37.023 | CQG WebAPI | Disconnected. 2024-08-05 13:39:37.023 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 13:39:37.023 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 13:39:37.083 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-05 13:39:37.083 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-05 13:39:37.159 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-05 13:39:37.159 | CQG WebSocket socket (1) | Closed. 2024-08-05 13:39:39.037 | 2024-08-05 13:39:39.037 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 13:39:39.037 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 13:39:39.509 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-05 13:39:39.509 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-05 13:39:39.509 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-05 13:39:39.559 | CQG WebSocket | Opening WebSocket. 2024-08-05 13:39:39.559 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 13:39:39.814 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 13:39:39.814 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 13:39:39.814 | CQG WebSocket | Server header | Sec-WebSocket-Accept: zkWPBudatqtbyqpHpa6ZpM8aVgM= 2024-08-05 13:39:39.814 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 13:39:39.814 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 13:39:39.814 | CQG WebSocket | Server header | 2024-08-05 13:39:39.814 | CQG WebSocket | Web socket state is now open. 2024-08-05 13:39:39.814 | CQG WebAPI | WebSocket connected. 2024-08-05 13:39:39.814 | CQG WebAPI | Sending market data logon message. 2024-08-05 13:39:40.075 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 13:39:40.075 | CQG WebAPI | Logon successful. Session Token = Ov2EONFZy+J9yWdIDD+qPXODih5sxunkbrNCUrtGr7QhzZYktOTx/IEHD4b4cJYWS3CCK0TpHnL 2024-08-05 13:39:40.075 | CQG WebAPI | Connected to server complete. 2024-08-05 13:39:40.077 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 13:39:40.077 | Updated verified funded futures trading account ending date to: 2024-09-04 12:39:40 2024-08-05 13:39:40.078 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 13:39:40.088 | Using symbol data fast lookup vector 2024-08-05 13:39:40.088 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 13:39:40.088 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 13:39:40.088 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 13:39:40.088 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 13:39:40.088 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 13:39:40.088 | Intraday chart data file opened for F.US.EPU24 2024-08-05 13:39:40.098 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 13:39:40.098 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 13:39:40.219 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 13:39:40.219 | Updated verified funded futures trading account ending date to: 2024-09-04 12:39:40 2024-08-05 13:39:40.219 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 13:39:40.321 | CQG WebAPI | Sending positions subscribe request. RequestID: 14091 2024-08-05 13:39:40.321 | CQG WebAPI | Sending orders subscribe request. RequestID: 14092 2024-08-05 13:43:18.577 | F.US.EPU24 Weekly #7 | Reloading chart. 2024-08-05 13:43:18.595 | F.US.EPU24 Daily #15 | Reloading chart. 2024-08-05 13:43:18.612 | F.US.EPU24 240 Min #5 | Reloading chart. 2024-08-05 13:43:18.631 | F.US.EPU24 60 Min #4 | Reloading chart. 2024-08-05 13:43:18.648 | F.US.EPU24 30 Min #1 | Reloading chart. 2024-08-05 13:43:18.665 | F.US.EPU24 15 Min #2 | Reloading chart. 2024-08-05 13:43:18.681 | F.US.EPU24 5 Min #3 | Reloading chart. 2024-08-05 13:43:18.745 | F.US.EPU24 5 Min #6 | Reloading chart. 2024-08-05 13:43:18.768 | F.US.EPU24 Weekly #7 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:43:18.770 | F.US.EPU24 Weekly #7 | Chart data loading complete. 2024-08-05 13:43:18.772 | F.US.EPU24 Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:43:18.773 | F.US.EPU24 Daily #15 | Chart data loading complete. 2024-08-05 13:43:18.774 | F.US.EPU24 240 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:43:18.774 | F.US.EPU24 240 Min #5 | Chart data loading complete. 2024-08-05 13:43:18.776 | F.US.EPU24 60 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:43:18.776 | F.US.EPU24 60 Min #4 | Chart data loading complete. 2024-08-05 13:43:18.778 | F.US.EPU24 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:43:18.779 | F.US.EPU24 30 Min #1 | Chart data loading complete. 2024-08-05 13:43:18.781 | F.US.EPU24 15 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:43:18.782 | F.US.EPU24 15 Min #2 | Chart data loading complete. 2024-08-05 13:43:18.784 | F.US.EPU24 5 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:43:18.785 | F.US.EPU24 5 Min #3 | Chart data loading complete. 2024-08-05 13:43:18.787 | F.US.EPU24 5 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:43:18.791 | F.US.EPU24 5 Min #6 | Chart data loading complete. 2024-08-05 13:43:19.095 | F.US.EPU24 Daily #15 | Reloading chart. 2024-08-05 13:43:19.127 | F.US.EPU24 Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:43:19.127 | F.US.EPU24 Daily #15 | Chart data loading complete. 2024-08-05 13:43:47.994 | ESU24-CME #2 | Reloading chart. 2024-08-05 13:43:48.322 | MESU24-CME #3 | Reloading chart. 2024-08-05 13:43:48.323 | MESU24-CME #3 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:43:48.327 | MESU24-CME #3 | Chart data loading complete. 2024-08-05 13:43:48.344 | ESU24-CME 5 Min #1 | Reloading chart. 2024-08-05 13:43:48.417 | ESU24-CME 1 Min #4 | Reloading chart. 2024-08-05 13:43:48.759 | CQG WebAPI | Starting real-time market data updates for: ESU24-CME. ID: 2 2024-08-05 13:43:48.759 | CQG WebAPI | Sending symbol resolution request for ESU24-CME. ID: 14093 2024-08-05 13:43:48.759 | CQG WebAPI | Requesting security definition data for: ESU24-CME. ID: 2 2024-08-05 13:43:48.759 | CQG WebAPI | Using primary service for historical data for ESU24-CME 2024-08-05 13:43:48.759 | Starting DelayedDownloadMonitoringTimer 2024-08-05 13:43:48.759 | Starting HDTimeoutTimer 2024-08-05 13:43:48.760 | Added historical Intraday data request for ESU24-CME to the queue. 2024-08-05 13:43:48.760 | Intraday data recording state for symbol ESU24-CME is set to download 'Pending'. 2024-08-05 13:43:48.762 | Triggering next historical data download in queue. 2024-08-05 13:43:48.762 | Delaying start of download for ESU24-CME. 2024-08-05 13:43:48.837 | Requesting market depth updates for: ESU24-CME if supported. NumLevels=1400 2024-08-05 13:43:48.837 | Separate subscription for market depth updates not supported. ESU24-CME 2024-08-05 13:43:48.838 | MESU24-CME #3 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:43:48.838 | CQG WebAPI | Starting real-time market data updates for: MESU24-CME. ID: 3 2024-08-05 13:43:48.838 | CQG WebAPI | Sending symbol resolution request for MESU24-CME. ID: 14094 2024-08-05 13:43:48.838 | CQG WebAPI | Requesting security definition data for: MESU24-CME. ID: 3 2024-08-05 13:43:48.838 | CQG WebAPI | Using primary service for historical data for MESU24-CME 2024-08-05 13:43:48.838 | Added historical Intraday data request for MESU24-CME to the queue. 2024-08-05 13:43:48.838 | Intraday data recording state for symbol MESU24-CME is set to download 'Pending'. 2024-08-05 13:43:48.838 | Triggering next historical data download in queue. 2024-08-05 13:43:48.983 | CQG WebAPI | Received message: Requested symbol was not found. 2024-08-05 13:43:48.983 | Symbol Error | ESU24-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2024-08-05 13:43:48.984 | CQG WebAPI | Received message: Requested symbol was not found. 2024-08-05 13:43:48.984 | Symbol Error | MESU24-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2024-08-05 13:43:49.767 | HD Request # 1 | Downloading Intraday chart data for ESU24-CME to the file ESU24-CME.scid. Service: cqg 2024-08-05 13:43:49.768 | HD Request # 1 | Download start date-time: 2024-08-05 13:16:13.000000. File last date-time: 2024-08-05 13:16:13.817000 2024-08-05 13:43:49.768 | HD Request # 1 | Error downloading historical Intraday data for ESU24-CME. The symbol is unknown to the server. 2024-08-05 13:43:49.768 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU24-CME 2024-08-05 13:43:49.768 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-08-05 12:16:13.817000 2024-08-05 13:43:49.768 | HD Request # 1 | Completion time: 0s. 2024-08-05 13:43:49.768 | HD Request # 1 | Intraday data download complete for ESU24-CME. Unique request ID: 1 2024-08-05 13:43:49.768 | Removing historical data download ID 1. 2024-08-05 13:43:49.768 | Real-time Intraday chart data file updates started for ESU24-CME 2024-08-05 13:43:49.768 | Intraday chart data file opened for ESU24-CME 2024-08-05 13:43:49.768 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-08-05 13:43:49.769 | 2024-08-05 13:43:49.769 | Triggering next historical data download in queue. 2024-08-05 13:43:49.769 | HD Request # 2 | Downloading Intraday chart data for MESU24-CME to the file MESU24-CME.scid. Service: cqg 2024-08-05 13:43:49.769 | HD Request # 2 | Download start date-time: 2024-07-29 16:30:59.000000. File last date-time: 2024-07-29 16:30:59.136002 2024-08-05 13:43:49.769 | HD Request # 2 | Error downloading historical Intraday data for MESU24-CME. The symbol is unknown to the server. 2024-08-05 13:43:49.769 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MESU24-CME 2024-08-05 13:43:49.770 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-07-29 15:30:59.136002 2024-08-05 13:43:49.770 | HD Request # 2 | Completion time: 0s. 2024-08-05 13:43:49.770 | HD Request # 2 | Intraday data download complete for MESU24-CME. Unique request ID: 2 2024-08-05 13:43:49.770 | Removing historical data download ID 2. 2024-08-05 13:43:49.770 | Real-time Intraday chart data file updates started for MESU24-CME 2024-08-05 13:43:49.770 | Intraday chart data file opened for MESU24-CME 2024-08-05 13:43:49.770 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-08-05 13:43:49.770 | 2024-08-05 13:43:49.770 | No download requests in the queue to start downloads for. 2024-08-05 13:43:50.124 | Requesting market depth updates for: MESU24-CME if supported. NumLevels=1400 2024-08-05 13:43:50.124 | Symbol Error | MESU24-CME is unknown, unavailable, or improperly formatted. Symbol is invalid during SubscribeToSymbolDOM 2024-08-05 13:44:06.312 | ESU24-CME #2 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:44:06.502 | ESU24-CME #2 | Chart data loading complete. 2024-08-05 13:44:09.020 | Loading market depth data. | Number times message added: 1 2024-08-05 13:44:10.702 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:44:10.712 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:44:10.849 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:44:10.850 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:44:13.152 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. | Number times message added: 1 2024-08-05 13:44:17.874 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. | Number times message added: 1 2024-08-05 13:44:22.606 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. | Number times message added: 1 2024-08-05 13:44:28.357 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. | Number times message added: 1 2024-08-05 13:44:32.767 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:44:32.777 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:44:32.995 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:44:32.997 | ESU24-CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:44:33.004 | ESU24-CME 5 Min #1 | Chart data loading complete. 2024-08-05 13:44:33.045 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:44:33.046 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:44:33.165 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:44:33.167 | ESU24-CME 1 Min #4 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:44:33.202 | ESU24-CME 1 Min #4 | Chart data loading complete. 2024-08-05 13:44:33.407 | ESU24-CME 5 Min #1 | Reloading chart. 2024-08-05 13:44:33.544 | ESU24-CME 1 Min #4 | Reloading chart. 2024-08-05 13:44:47.692 | Loading market depth data. | Number times message added: 1 2024-08-05 13:44:49.415 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:44:49.416 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:44:49.537 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:44:49.537 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:44:51.877 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. | Number times message added: 1 2024-08-05 13:44:56.664 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. | Number times message added: 1 2024-08-05 13:45:01.475 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. | Number times message added: 1 2024-08-05 13:45:07.617 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. | Number times message added: 1 2024-08-05 13:45:12.059 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:45:12.059 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:45:12.235 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:45:12.237 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:45:12.280 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:45:12.282 | ESU24-CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:45:12.290 | ESU24-CME 5 Min #1 | Chart data loading complete. 2024-08-05 13:45:12.374 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:45:12.376 | ESU24-CME 1 Min #4 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:45:12.409 | ESU24-CME 1 Min #4 | Chart data loading complete. 2024-08-05 13:50:18.467 | File >> Reconnect selected. 2024-08-05 13:50:18.490 | CQG WebAPI | Sending Web API Logoff message. 2024-08-05 13:50:18.490 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-05 13:50:18.490 | CQG WebSocket | WebSocket closed. 2024-08-05 13:50:18.490 | CQG WebAPI | WebSocket closed. 2024-08-05 13:50:18.490 | CQG WebAPI | Disconnected. 2024-08-05 13:50:18.490 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 13:50:18.490 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 13:50:18.615 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-05 13:50:18.615 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-05 13:50:18.667 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-05 13:50:18.667 | CQG WebSocket socket (1) | Closed. 2024-08-05 13:50:20.479 | 2024-08-05 13:50:20.479 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 13:50:20.479 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 13:50:20.981 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-05 13:50:20.981 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-05 13:50:20.981 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-05 13:50:21.047 | CQG WebSocket | Opening WebSocket. 2024-08-05 13:50:21.047 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 13:50:21.219 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 13:50:21.219 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 13:50:21.219 | CQG WebSocket | Server header | Sec-WebSocket-Accept: XAzkgOGvcqS7jMurOjO+IhAC5So= 2024-08-05 13:50:21.219 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 13:50:21.219 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 13:50:21.219 | CQG WebSocket | Server header | 2024-08-05 13:50:21.219 | CQG WebSocket | Web socket state is now open. 2024-08-05 13:50:21.219 | CQG WebAPI | WebSocket connected. 2024-08-05 13:50:21.219 | CQG WebAPI | Sending market data logon message. 2024-08-05 13:50:21.485 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 13:50:21.485 | CQG WebAPI | Logon successful. Session Token = noL8IjxT7MjJA70RmIRK8rdif01Bbbc5Z9vifWkoXlM4R+WJ0GclJly6V2zem6hUJ2r5SJ/SfEO 2024-08-05 13:50:21.485 | CQG WebAPI | Connected to server complete. 2024-08-05 13:50:21.487 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 13:50:21.487 | Updated verified funded futures trading account ending date to: 2024-09-04 12:50:21 2024-08-05 13:50:21.517 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 13:50:21.619 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 13:50:21.619 | Updated verified funded futures trading account ending date to: 2024-09-04 12:50:21 2024-08-05 13:50:21.619 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 13:50:21.686 | Using symbol data fast lookup vector 2024-08-05 13:50:21.686 | CQG WebAPI | Starting real-time market data updates for: ESU24-CME. ID: 1 2024-08-05 13:50:21.686 | CQG WebAPI | Sending symbol resolution request for ESU24-CME. ID: 14097 2024-08-05 13:50:21.686 | CQG WebAPI | Requesting security definition data for: ESU24-CME. ID: 1 2024-08-05 13:50:21.686 | Requesting market depth updates for: ESU24-CME if supported. NumLevels=1400 2024-08-05 13:50:21.686 | Separate subscription for market depth updates not supported. ESU24-CME 2024-08-05 13:50:21.686 | CQG WebAPI | Using primary service for historical data for ESU24-CME 2024-08-05 13:50:21.686 | Added historical Intraday data request for ESU24-CME to the queue. 2024-08-05 13:50:21.686 | Intraday data recording state for symbol ESU24-CME is set to download 'Pending'. 2024-08-05 13:50:21.686 | Triggering next historical data download in queue. 2024-08-05 13:50:21.688 | Delaying start of download for ESU24-CME. 2024-08-05 13:50:21.689 | CQG WebAPI | Starting real-time market data updates for: MESU24-CME. ID: 2 2024-08-05 13:50:21.689 | CQG WebAPI | Sending symbol resolution request for MESU24-CME. ID: 14098 2024-08-05 13:50:21.689 | CQG WebAPI | Requesting security definition data for: MESU24-CME. ID: 2 2024-08-05 13:50:21.689 | CQG WebAPI | Using primary service for historical data for MESU24-CME 2024-08-05 13:50:21.689 | Added historical Intraday data request for MESU24-CME to the queue. 2024-08-05 13:50:21.689 | Intraday data recording state for symbol MESU24-CME is set to download 'Pending'. 2024-08-05 13:50:21.689 | Triggering next historical data download in queue. 2024-08-05 13:50:21.690 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 3 2024-08-05 13:50:21.690 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 3 2024-08-05 13:50:21.691 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 13:50:21.691 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 13:50:21.691 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 13:50:21.691 | Intraday chart data file opened for F.US.EPU24 2024-08-05 13:50:21.728 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 13:50:21.728 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 13:50:21.736 | CQG WebAPI | Sending positions subscribe request. RequestID: 14099 2024-08-05 13:50:21.736 | CQG WebAPI | Sending orders subscribe request. RequestID: 14100 2024-08-05 13:50:21.827 | CQG WebAPI | Received message: Requested symbol was not found. 2024-08-05 13:50:21.828 | Symbol Error | ESU24-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2024-08-05 13:50:21.828 | CQG WebAPI | Received message: Requested symbol was not found. 2024-08-05 13:50:21.828 | Symbol Error | MESU24-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2024-08-05 13:50:22.104 | HD Request # 3 | Downloading Intraday chart data for ESU24-CME to the file ESU24-CME.scid. Service: cqg 2024-08-05 13:50:22.105 | HD Request # 3 | Download start date-time: 2024-08-05 13:16:13.000000. File last date-time: 2024-08-05 13:16:13.817000 2024-08-05 13:50:22.105 | HD Request # 3 | Error downloading historical Intraday data for ESU24-CME. The symbol is unknown to the server. 2024-08-05 13:50:22.105 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU24-CME 2024-08-05 13:50:22.107 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2024-08-05 12:16:13.817000 2024-08-05 13:50:22.107 | HD Request # 3 | Completion time: 0s. 2024-08-05 13:50:22.107 | HD Request # 3 | Intraday data download complete for ESU24-CME. Unique request ID: 3 2024-08-05 13:50:22.107 | Removing historical data download ID 3. 2024-08-05 13:50:22.107 | Real-time Intraday chart data file updates started for ESU24-CME 2024-08-05 13:50:22.107 | Intraday chart data file opened for ESU24-CME 2024-08-05 13:50:22.107 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-08-05 13:50:22.107 | 2024-08-05 13:50:22.107 | Triggering next historical data download in queue. 2024-08-05 13:50:22.107 | HD Request # 4 | Downloading Intraday chart data for MESU24-CME to the file MESU24-CME.scid. Service: cqg 2024-08-05 13:50:22.108 | HD Request # 4 | Download start date-time: 2024-07-29 16:30:59.000000. File last date-time: 2024-07-29 16:30:59.136002 2024-08-05 13:50:22.108 | HD Request # 4 | Error downloading historical Intraday data for MESU24-CME. The symbol is unknown to the server. 2024-08-05 13:50:22.108 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MESU24-CME 2024-08-05 13:50:22.109 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-07-29 15:30:59.136002 2024-08-05 13:50:22.109 | HD Request # 4 | Completion time: 0s. 2024-08-05 13:50:22.109 | HD Request # 4 | Intraday data download complete for MESU24-CME. Unique request ID: 4 2024-08-05 13:50:22.109 | Removing historical data download ID 4. 2024-08-05 13:50:22.109 | Real-time Intraday chart data file updates started for MESU24-CME 2024-08-05 13:50:22.109 | Intraday chart data file opened for MESU24-CME 2024-08-05 13:50:22.109 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-08-05 13:50:22.109 | 2024-08-05 13:50:22.109 | No download requests in the queue to start downloads for. 2024-08-05 13:50:26.482 | Requesting market depth updates for: MESU24-CME if supported. NumLevels=1400 2024-08-05 13:50:26.482 | Symbol Error | MESU24-CME is unknown, unavailable, or improperly formatted. Symbol is invalid during SubscribeToSymbolDOM 2024-08-05 13:51:00.284 | CQG WebAPI | Sending Web API Logoff message. 2024-08-05 13:51:00.284 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-05 13:51:00.284 | CQG WebSocket | WebSocket closed. 2024-08-05 13:51:00.284 | CQG WebAPI | WebSocket closed. 2024-08-05 13:51:00.284 | CQG WebAPI | Disconnected. 2024-08-05 13:51:00.284 | CQG WebSocket socket (0) | CloseSocket call. | Number times message added: 2 2024-08-05 13:51:00.284 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 13:51:00.341 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-05 13:51:00.341 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-05 13:51:00.387 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-05 13:51:00.387 | CQG WebSocket socket (1) | Closed. 2024-08-05 13:51:00.462 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 2. 2024-08-05 13:51:00.462 | Current selected Data/Trading service: SC Data - All Services 2024-08-05 13:51:02.251 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-08-05 13:51:02.282 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 13:51:02.299 | ESU24-CME 5 Min #6 | Reloading chart. 2024-08-05 13:51:02.509 | Symbol settings MD5 received. Request ID: 2. 2024-08-05 13:51:02.509 | Requested symbol settings for service code scdataallservices. Request ID: 3. 2024-08-05 13:51:02.511 | ESU24-CME #4 | Reloading chart. 2024-08-05 13:51:02.517 | ESU24-CME 5 Min #2 | Reloading chart. 2024-08-05 13:51:02.521 | ESU24-CME 5 Min #5 | Reloading chart. 2024-08-05 13:51:02.527 | ESU24-CME 1 Sec #12 | Reloading chart. 2024-08-05 13:51:02.532 | ESU24-CME 3.75 Range #7 | Reloading chart. 2024-08-05 13:51:02.536 | ESU24-CME 30 Min #6 | Reloading chart. 2024-08-05 13:51:02.541 | ESU24-CME 20000 Volume #10 | Reloading chart. 2024-08-05 13:51:02.546 | ESU24-CME #8 | Reloading chart. 2024-08-05 13:51:02.551 | ESU24-CME 1 Min #11 | Reloading chart. 2024-08-05 13:51:02.556 | ESU24-CME 5 Min #3 | Reloading chart. 2024-08-05 13:51:08.674 | ESU24-CME 30 Min #1 | Reloading chart. 2024-08-05 13:51:08.705 | ESU24-CME Weekly #7 | Reloading chart. 2024-08-05 13:51:08.716 | ESU24-CME Daily #15 | Reloading chart. 2024-08-05 13:51:08.723 | ESU24-CME 240 Min #5 | Reloading chart. 2024-08-05 13:51:08.730 | ESU24-CME 60 Min #4 | Reloading chart. 2024-08-05 13:51:08.737 | ESU24-CME 30 Min #1 | Reloading chart. 2024-08-05 13:51:08.743 | ESU24-CME 15 Min #2 | Reloading chart. 2024-08-05 13:51:08.755 | ESU24-CME 5 Min #3 | Reloading chart. 2024-08-05 13:51:08.773 | 2024-08-05 13:51:08.773 | SC Data - All Services | Connected to server complete. 2024-08-05 13:51:08.773 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 13:51:08.885 | ESU24-CME Weekly #7 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:51:08.885 | ESU24-CME Weekly #7 | Chart data loading complete. 2024-08-05 13:51:08.892 | Mapping ESU24-CME to ESU24. Service code: cme 2024-08-05 13:51:08.892 | Using symbol data fast lookup vector 2024-08-05 13:51:08.892 | Delayed Data Feed | Starting real-time market data updates for: ESU24-CME (ESU24). ID: 1 Service code: cme 2024-08-05 13:51:08.895 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2024-08-05 13:51:08.899 | Delayed Data Feed | Requesting security definition data for: ESU24-CME (ESU24). ID: 1 2024-08-05 13:51:08.899 | Requesting market depth updates for: ESU24-CME if supported. NumLevels=100 2024-08-05 13:51:08.899 | Starting DelayedDownloadMonitoringTimer 2024-08-05 13:51:08.899 | Starting HDTimeoutTimer 2024-08-05 13:51:08.899 | Added historical Intraday data request for ESU24-CME to the queue. 2024-08-05 13:51:08.899 | Intraday data recording state for symbol ESU24-CME is set to download 'Pending'. 2024-08-05 13:51:08.901 | Triggering next historical data download in queue. 2024-08-05 13:51:08.903 | Delaying start of download for ESU24-CME. 2024-08-05 13:51:08.907 | Mapping MESU24-CME to MESU24. Service code: cme 2024-08-05 13:51:08.907 | Delayed Data Feed | Starting real-time market data updates for: MESU24-CME (MESU24). ID: 2 Service code: cme 2024-08-05 13:51:08.907 | Delayed Data Feed | Requesting security definition data for: MESU24-CME (MESU24). ID: 2 2024-08-05 13:51:08.908 | Added historical Intraday data request for MESU24-CME to the queue. 2024-08-05 13:51:08.908 | Intraday data recording state for symbol MESU24-CME is set to download 'Pending'. 2024-08-05 13:51:08.908 | Triggering next historical data download in queue. 2024-08-05 13:51:09.035 | ESU24-CME Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:51:09.035 | ESU24-CME Daily #15 | Chart data loading complete. 2024-08-05 13:51:09.036 | DTC Client socket (3) | Creating socket. 2024-08-05 13:51:09.036 | DTC Client socket (3) | New receive buffer size: 0 2024-08-05 13:51:09.036 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2024-08-05 13:51:09.255 | Delayed Data Feed | Network connection to server complete. 2024-08-05 13:51:09.255 | Delayed Data Feed | Starting socket receive thread. 2024-08-05 13:51:09.255 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-05 13:51:09.454 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-08-05 13:51:09.454 | Delayed Data Feed | Sending logon request message. 2024-08-05 13:51:09.962 | Delayed Data Feed | Received logon response. 2024-08-05 13:51:09.962 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-08-05 13:51:09.962 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-05 13:51:09.962 | Delayed Data Feed | Successfully connected. 2024-08-05 13:51:09.962 | Delayed Data Feed | Trading is not supported. 2024-08-05 13:51:09.962 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-08-05 13:51:09.966 | Delayed Data Feed (Market Orders Data) | Connecting to the server ds28.sierracharts.com. Port 10042 2024-08-05 13:51:09.969 | Delayed Data Feed | Restarting real-time data updates for symbol: ESU24-CME -> ESU24. Market Depth data restarted. 2024-08-05 13:51:09.969 | Delayed Data Feed | Restarting real-time data updates for symbol: MESU24-CME -> MESU24 2024-08-05 13:51:10.064 | DTC Client socket (1) | Creating socket. 2024-08-05 13:51:10.064 | DTC Client socket (1) | New receive buffer size: 0 2024-08-05 13:51:10.064 | DTC Client socket (1) | Connecting to IP: 67.214.125.5. 2024-08-05 13:51:10.395 | Delayed Data Feed | Clearing market depth for ESU24-CME 2024-08-05 13:51:10.395 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESU24-CME.2024-08-05.depth 2024-08-05 13:51:10.396 | Delayed Data Feed | Setting external service identifier for symbol ESU24-CME to 118 2024-08-05 13:51:10.396 | Delayed Data Feed | Received security definition for symbol ESU24-CME 2024-08-05 13:51:10.396 | Delayed Data Feed | Setting external service identifier for symbol MESU24-CME to 7114 2024-08-05 13:51:10.396 | Delayed Data Feed | Received security definition for symbol MESU24-CME 2024-08-05 13:51:10.397 | Delayed Data Feed (Market Orders Data) | Network connection to server complete. 2024-08-05 13:51:10.397 | Delayed Data Feed (Market Orders Data) | Starting socket receive thread. 2024-08-05 13:51:10.397 | Delayed Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-05 13:51:20.651 | DTC Client socket (1) | Socket gracefully closed by remote side. | Number times message added: 1 2024-08-05 13:51:21.035 | Symbol settings received. Request ID: 3. 2024-08-05 13:52:23.513 | Loading market depth data. 2024-08-05 13:52:25.963 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:52:25.963 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:52:26.032 | Loading market depth data. 2024-08-05 13:52:28.636 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:52:28.637 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:52:28.660 | Loading market depth data. 2024-08-05 13:52:30.404 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:52:30.532 | Loading market depth data. 2024-08-05 13:52:31.245 | Delayed Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2024-08-05 13:52:31.245 | Delayed Data Feed (Market Orders Data) | Sending logon request message. 2024-08-05 13:52:31.245 | Delayed Data Feed (Market Orders Data) | Server has requested a logoff. Reason: No Logon message received. 2024-08-05 13:52:31.245 | Delayed Data Feed (Market Orders Data) | Failed connections: 1 2024-08-05 13:52:31.245 | Delayed Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2024-08-05 13:52:31.245 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-05 13:52:31.246 | DTC Client socket (1) | CloseSocket call. 2024-08-05 13:52:31.246 | DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 13:52:31.246 | Delayed Data Feed (Market Orders Data) | Disconnected from the server. 2024-08-05 13:52:31.246 | Delayed Data Feed (Market Orders Data) | Data feed disconnected. Will reconnect in 0 seconds. 2024-08-05 13:52:31.249 | ESU24-CME[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.547 | DTC Client socket (1) | Write has completed. Shutdown being performed. 2024-08-05 13:52:31.547 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-08-05 13:52:31.547 | DTC Client socket (1) | Closed. 2024-08-05 13:52:31.593 | ESU24-CME[M] 5 Min #6 | Chart data loading complete. 2024-08-05 13:52:31.597 | ESU24-CME[M] 240 Min #5 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.597 | ESU24-CME[M] 240 Min #5 | Chart data loading complete. 2024-08-05 13:52:31.600 | ESU24-CME[M] 60 Min #4 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.656 | ESU24-CME[M] 60 Min #4 | Chart data loading complete. 2024-08-05 13:52:31.659 | ESU24-CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.662 | ESU24-CME[M] 30 Min #1 | Chart data loading complete. 2024-08-05 13:52:31.664 | ESU24-CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.679 | ESU24-CME[M] 5 Min #3 | Chart data loading complete. 2024-08-05 13:52:31.682 | ESU24-CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.690 | ESU24-CME[M] 15 Min #2 | Chart data loading complete. 2024-08-05 13:52:31.702 | ESU24-CME[M] #8 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:52:31.835 | ESU24-CME[M] #8 | Chart data loading complete. 2024-08-05 13:52:31.837 | ESU24-CME[M] #4 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:52:32.391 | ESU24-CME[M] #4 | Chart data loading complete. 2024-08-05 13:52:32.462 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:52:32.465 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:52:32.508 | ESU24-CME[M] 5 Min #3 | Chart data loading complete. 2024-08-05 13:52:32.509 | ESU24-CME[M] 30 Min #6 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:52:32.526 | ESU24-CME[M] 30 Min #6 | Chart data loading complete. 2024-08-05 13:52:32.528 | ESU24-CME[M] 20000 Volume #10 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:52:32.549 | ESU24-CME[M] 20000 Volume #10 | Chart data loading complete. 2024-08-05 13:52:33.409 | Starting DelayedDownloadMonitoringTimer 2024-08-05 13:52:33.409 | Starting HDTimeoutTimer 2024-08-05 13:52:33.409 | Added historical Daily data request for ESU24-CME to the queue. 2024-08-05 13:52:33.412 | Triggering next historical data download in queue. 2024-08-05 13:52:33.420 | HD Request # 5 | Downloading Historical Daily chart data for ESU24-CME. Starting date: 2024-07-31. Service: scdataallservices 2024-08-05 13:52:33.551 | HD Request # 6 | Downloading Intraday chart data for ESU24-CME to the file ESU24-CME.scid. Service: cme 2024-08-05 13:52:33.552 | HD Request # 6 | Download start date-time: 2024-08-05 13:16:13.000000. File last date-time: 2024-08-05 13:16:13.817000 2024-08-05 13:52:33.552 | HD Request # 6 | Using server: ds28.sierracharts.com port 10150 2024-08-05 13:52:33.552 | Socket (4) | Creating socket. 2024-08-05 13:52:33.552 | Socket (4) | New receive buffer size: 0 2024-08-05 13:52:33.552 | Socket (4) | Connecting to IP: 67.214.125.5. 2024-08-05 13:52:33.653 | ESU24-CME[M] 20000 Volume #10 | Reloading chart. 2024-08-05 13:52:33.658 | ESU24-CME[M] 5 Min #3 | Reloading chart. 2024-08-05 13:52:33.663 | Requesting market depth updates for: MESU24-CME if supported. NumLevels=100 2024-08-05 13:52:33.667 | ESU24-CME[M] Weekly #7 | Reloading chart. 2024-08-05 13:52:33.675 | ESU24-CME[M] Daily #15 | Reloading chart. 2024-08-05 13:52:33.683 | Delayed Data Feed (Market Orders Data) | Connecting to the server ds26.sierracharts.com. Port 10042 2024-08-05 13:52:33.732 | DTC Client socket (5) | Creating socket. 2024-08-05 13:52:33.732 | DTC Client socket (5) | New receive buffer size: 0 2024-08-05 13:52:33.732 | DTC Client socket (5) | Connecting to IP: 69.39.70.243. 2024-08-05 13:52:33.778 | ESU24-CME[M] Weekly #7 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:52:33.778 | ESU24-CME[M] Weekly #7 | Chart data loading complete. 2024-08-05 13:52:33.795 | ESU24-CME[M] Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:52:33.796 | ESU24-CME[M] Daily #15 | Chart data loading complete. 2024-08-05 13:52:33.826 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-08-05 13:52:33.826 | HD Request # 6 | Sending historical data logon request message. 2024-08-05 13:52:33.875 | Delayed Data Feed | Clearing market depth for MESU24-CME 2024-08-05 13:52:33.889 | Delayed Data Feed (Market Orders Data) | Network connection to server complete. 2024-08-05 13:52:33.889 | Delayed Data Feed (Market Orders Data) | Starting socket receive thread. 2024-08-05 13:52:33.889 | Delayed Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-05 13:52:34.212 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-08-05 13:16:13. Record interval: 0. Symbol: ESU24 2024-08-05 13:52:34.339 | HD Request # 6 | Decompressing data. 2024-08-05 13:52:34.379 | HD Request # 5 | Requesting historical Daily data for ESU24 starting at 2024-07-30. SC External HD service. 2024-08-05 13:52:34.493 | HD Request # 6 | Receiving Intraday data for ESU24-CME starting at 2024-08-05 13:16:13.027000 2024-08-05 13:52:34.658 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:52:34.707 | Loaded depth data records for ESU24-CME 2024-07-16 from 2024-07-16 11:07:57.954000 to 2024-07-16 15:23:39.771000. 2024-08-05 13:52:34.824 | HD Request # 6 | Timestamp of first Intraday data file record written: 2024-08-05 13:16:13.983000. 2024-08-05 13:52:35.333 | Socket (4) | CloseSocket call. 2024-08-05 13:52:35.333 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-05 13:52:35.447 | Historical data download thread signaled to stop. 2024-08-05 13:52:35.449 | HD Request # 6 | Received 94853 Intraday data records from 2024-08-05 13:16:13.027000 to 2024-08-05 13:42:33.962001 (26.3 minutes. Delay: 10.0 minutes) and wrote 94786 records for ESU24-CME 2024-08-05 13:52:35.467 | Socket (4) | Socket gracefully closed by remote side. 2024-08-05 13:52:35.467 | Socket (4) | Closed. 2024-08-05 13:52:36.939 | Loading market depth data. 2024-08-05 13:52:38.761 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-08-05 12:42:33.962001 2024-08-05 13:52:38.761 | HD Request # 6 | Completion time: 5s. 2024-08-05 13:52:38.761 | HD Request # 6 | Intraday data download complete for ESU24-CME. Unique request ID: 5 2024-08-05 13:52:38.761 | Removing historical data download ID 5. 2024-08-05 13:52:38.761 | Real-time Intraday chart data file updates started for ESU24-CME 2024-08-05 13:52:38.761 | Intraday chart data file opened for ESU24-CME 2024-08-05 13:52:38.761 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2024-08-05 13:52:38.786 | 2024-08-05 13:52:38.786 | Triggering next historical data download in queue. 2024-08-05 13:52:38.787 | Delayed Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2024-08-05 13:52:38.787 | Delayed Data Feed (Market Orders Data) | Sending logon request message. 2024-08-05 13:52:38.788 | Opened cached Intraday file: C:\SierraChart\Data\ESU24-CME.scid. Thread ID: 26404 2024-08-05 13:52:38.789 | HD Request # 7 | Downloading Intraday chart data for MESU24-CME to the file MESU24-CME.scid. Service: cme 2024-08-05 13:52:38.790 | HD Request # 7 | Download start date-time: 2024-07-29 16:30:59.000000. File last date-time: 2024-07-29 16:30:59.136002 2024-08-05 13:52:38.790 | HD Request # 7 | Using server: ds32.sierracharts.com port 10149 2024-08-05 13:52:38.793 | Socket (1) | Creating socket. 2024-08-05 13:52:38.793 | Socket (1) | New receive buffer size: 0 2024-08-05 13:52:38.793 | Socket (1) | Connecting to IP: 67.214.125.3. 2024-08-05 13:52:39.061 | HD Request # 7 | Setting DTC encoding to Binary VLS 2024-08-05 13:52:39.061 | HD Request # 7 | Sending historical data logon request message. 2024-08-05 13:52:39.212 | HD Request # 5 | Receiving historical Daily data for ESU24-CME starting at 2024-07-31. 2024-08-05 13:52:39.212 | HD Request # 5 | Writing historical Daily data to the file ESU24-CME.dly. 2024-08-05 13:52:39.223 | HD Request # 5 | Bytes received: 246 2024-08-05 13:52:39.223 | HD Request # 5 | Received 4 Daily data records from 2024-07-31 00:00:00 to 2024-08-02 00:00:00 (3.0 days) and wrote 3 records for ESU24-CME 2024-08-05 13:52:39.223 | HD Request # 5 | Completion time: 6s. 2024-08-05 13:52:39.223 | HD Request # 5 | Daily data download complete for ESU24-CME. Unique request ID: 7 2024-08-05 13:52:39.223 | Removing historical data download ID 7. 2024-08-05 13:52:39.223 | 2024-08-05 13:52:39.223 | No download requests in the queue to start downloads for. 2024-08-05 13:52:39.445 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-07-29 16:30:59. Record interval: 0. Symbol: MESU24 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Received logon response. 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Successfully connected. 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Trading is not supported. 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Starting market orders updates for: ESU24. MinimumMarketByOrderQuantity: 20. Service code: cme 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESU24-CME -> ESU24 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Starting market orders updates for: MESU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-08-05 13:52:39.511 | Delayed Data Feed (Market Orders Data) | Restarting market orders data for symbol: MESU24-CME -> MESU24 2024-08-05 13:52:39.581 | HD Request # 7 | Decompressing data. 2024-08-05 13:52:39.747 | HD Request # 7 | Receiving Intraday data for MESU24-CME starting at 2024-07-29 16:30:59.020000 2024-08-05 13:52:40.094 | HD Request # 7 | Timestamp of first Intraday data file record written: 2024-07-29 16:30:59.204000. 2024-08-05 13:52:42.403 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:52:45.281 | ESU24-CME[M] Daily #15 | Reloading chart. 2024-08-05 13:52:45.738 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:52:45.739 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:52:46.118 | Loading market depth data. 2024-08-05 13:52:46.265 | ESU24-CME[M] Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:52:46.265 | ESU24-CME[M] Daily #15 | Chart data loading complete. 2024-08-05 13:52:46.881 | ESU24-CME[M] Weekly #7 | Reloading chart. 2024-08-05 13:52:47.084 | Loaded depth data records for ESU24-CME 2024-07-17 from 2024-07-17 01:56:53.447000 to 2024-07-17 15:43:49.130000. 2024-08-05 13:52:47.086 | ESU24-CME[M] Weekly #7 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:52:47.086 | ESU24-CME[M] Weekly #7 | Chart data loading complete. 2024-08-05 13:52:52.558 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:52:58.061 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:52:58.070 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:53:01.421 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:53:02.265 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:53:09.789 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:53:10.944 | Socket (1) | CloseSocket call. 2024-08-05 13:53:10.944 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-05 13:53:10.958 | Historical data download thread signaled to stop. 2024-08-05 13:53:11.026 | HD Request # 7 | Received 4064973 Intraday data records from 2024-07-29 16:30:59.020000 to 2024-08-05 13:43:06.655000 (6.9 days. Delay: 10.1 minutes) and wrote 4064968 records for MESU24-CME 2024-08-05 13:53:11.084 | Socket (1) | Socket gracefully closed by remote side. 2024-08-05 13:53:11.084 | Socket (1) | Closed. 2024-08-05 13:53:11.386 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-08-05 12:43:06.655000 2024-08-05 13:53:11.386 | HD Request # 7 | Completion time: 33s. 2024-08-05 13:53:11.386 | HD Request # 7 | Intraday data download complete for MESU24-CME. Unique request ID: 6 2024-08-05 13:53:11.386 | Removing historical data download ID 6. 2024-08-05 13:53:11.386 | Real-time Intraday chart data file updates started for MESU24-CME 2024-08-05 13:53:11.386 | Intraday chart data file opened for MESU24-CME 2024-08-05 13:53:11.386 | HD Request # 7 | Enabling Intraday chart updating for symbol. 2024-08-05 13:53:11.386 | 2024-08-05 13:53:11.386 | No download requests in the queue to start downloads for. 2024-08-05 13:53:11.387 | Opened cached Intraday file: C:\SierraChart\Data\MESU24-CME.scid. Thread ID: 26404 2024-08-05 13:53:13.792 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:53:14.827 | Loaded depth data records for ESU24-CME 2024-07-18 from 2024-07-18 09:43:54.633000 to 2024-07-18 19:59:59.866000. 2024-08-05 13:53:20.011 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:53:31.685 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:53:32.755 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:53:39.695 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:53:40.434 | Loaded depth data records for ESU24-CME 2024-07-19 from 2024-07-18 20:00:00.008000 to 2024-07-19 17:00:00.064000. 2024-08-05 13:53:40.452 | Loaded depth data records for ESU24-CME 2024-07-20 from 2024-07-19 22:43:32.504843 to 2024-07-19 22:33:30.818000. 2024-08-05 13:53:40.900 | Loaded depth data records for ESU24-CME 2024-07-21 from 2024-07-21 03:03:03.774045 to 2024-07-21 19:59:59.974000. 2024-08-05 13:53:46.742 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:53:54.395 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. 2024-08-05 13:53:59.654 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:54:03.189 | Loaded depth data records for ESU24-CME 2024-07-22 from 2024-07-21 20:00:00.020000 to 2024-07-22 19:59:59.794000. 2024-08-05 13:54:06.639 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. 2024-08-05 13:54:10.088 | Loaded depth data records for ESU24-CME 2024-07-23 from 2024-07-22 20:00:00.007000 to 2024-07-23 19:59:59.870000. 2024-08-05 13:54:12.613 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. 2024-08-05 13:54:17.837 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:54:19.432 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:54:19.433 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:54:20.727 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:54:21.336 | ESU24-CME[M] 5 Min #5 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:54:21.531 | ESU24-CME[M] 5 Min #5 | Chart data loading complete. 2024-08-05 13:54:21.733 | ESU24-CME[M] 5 Min #5 | Reloading chart. 2024-08-05 13:54:25.351 | ESU24-CME[M] 5 Min #3 | Chart data loading complete. 2024-08-05 13:54:27.264 | Loaded depth data records for ESU24-CME 2024-07-24 from 2024-07-23 20:00:00.015000 to 2024-07-24 15:02:05.346302. 2024-08-05 13:54:29.169 | ESU24-CME[M] 20000 Volume #10 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:54:29.188 | ESU24-CME[M] 20000 Volume #10 | Chart data loading complete. 2024-08-05 13:54:29.754 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:54:29.755 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:54:30.354 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. 2024-08-05 13:54:30.674 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:54:31.059 | ESU24-CME[M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:54:31.312 | ESU24-CME[M] 5 Min #2 | Chart data loading complete. 2024-08-05 13:54:31.673 | ESU24-CME[M] 5 Min #2 | Reloading chart. 2024-08-05 13:54:32.911 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:54:32.912 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:54:33.580 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:54:33.657 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:54:33.657 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:54:33.743 | ESU24-CME[M] 1 Min #11 | + Error reading record for update Intraday chart. Invalid cache index 2024-08-05 13:54:33.743 | ESU24-CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:54:36.210 | ESU24-CME[M] 1 Min #11 | Chart data loading complete. 2024-08-05 13:54:38.745 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:54:39.030 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. 2024-08-05 13:54:39.875 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:54:39.876 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:54:40.006 | ESU24-CME[M] 1 Min #11 | Reloading chart. 2024-08-05 13:54:40.319 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:54:40.456 | ESU24-CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:54:40.490 | Chart #1 has tagged chart #10 for full recalculation. Chartbook: DepthMarket.Cht 2024-08-05 13:54:40.490 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: DepthMarket.Cht 2024-08-05 13:54:40.490 | ESU24-CME[M] 30 Min #1 | Chart data loading complete. 2024-08-05 13:54:40.777 | ESU24-CME[M] 30 Min #1 | Reloading chart. 2024-08-05 13:54:43.327 | Delayed Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2024-08-05 13:54:43.327 | DTC Client socket (5) | CloseSocket call. 2024-08-05 13:54:43.327 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2024-08-05 13:54:43.327 | Delayed Data Feed (Market Orders Data) | Disconnected from the server. 2024-08-05 13:54:43.328 | Delayed Data Feed | Waiting for socket receive thread to end 2024-08-05 13:54:43.328 | DTC Client socket (3) | CloseSocket call. 2024-08-05 13:54:43.328 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2024-08-05 13:54:43.328 | Delayed Data Feed | Disconnected from the server. 2024-08-05 13:54:43.329 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-08-05 13:54:43.411 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 4. 2024-08-05 13:54:43.411 | Current selected Data/Trading service: CQG WebAPI 2024-08-05 13:54:43.616 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-08-05 13:54:43.616 | DTC Client socket (3) | Closed. 2024-08-05 13:54:43.724 | DTC Client socket (5) | Socket gracefully closed by remote side. 2024-08-05 13:54:43.724 | DTC Client socket (5) | Closed. 2024-08-05 13:54:47.901 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:54:47.922 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:54:47.938 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:54:48.490 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:54:48.499 | ESU24-CME[M] 1 Sec #12 | StartDateTimeForLoadingOrderFills: 2024-08-05 00:00:00 2024-08-05 13:54:56.153 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:55:06.429 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 19:59:59.958000. 2024-08-05 13:55:07.731 | ESU24-CME[M] 1 Sec #12 | Chart data loading complete. 2024-08-05 13:55:11.968 | Loading market depth data. 2024-08-05 13:55:15.068 | Loaded depth data records for ESU24-CME 2024-08-02 from 2024-08-01 20:00:00.002000 to 2024-08-02 14:08:27.738000. 2024-08-05 13:55:15.068 | Loaded depth data records for ESU24-CME 2024-08-03 from 2024-08-02 23:18:52.970000 to 2024-08-02 23:18:52.970000. 2024-08-05 13:55:15.378 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:55:15.379 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:55:15.536 | Loaded depth data records for ESU24-CME 2024-08-05 from 2024-08-05 00:56:51.602000 to 2024-08-05 08:16:13.817000. 2024-08-05 13:55:15.555 | Loading market depth data. | Number times message added: 1 2024-08-05 13:55:18.889 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:55:18.889 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:55:19.191 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:55:19.191 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:55:20.343 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:55:23.127 | Loading market depth data. 2024-08-05 13:55:24.956 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. | Number times message added: 1 2024-08-05 13:55:29.043 | Loaded depth data records for ESU24-CME 2024-07-26 from 2024-07-26 10:59:48.461000 to 2024-07-26 14:30:50.799000. 2024-08-05 13:55:29.045 | Loaded depth data records for ESU24-CME 2024-07-27 from 2024-07-26 21:34:50.362000 to 2024-07-26 21:34:50.362000. 2024-08-05 13:55:36.023 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:55:37.447 | Loaded depth data records for ESU24-CME 2024-07-29 from 2024-07-29 10:47:18.622000 to 2024-07-29 19:59:59.995000. 2024-08-05 13:55:39.792 | Symbol settings MD5 received. Request ID: 4. 2024-08-05 13:55:39.793 | Requested symbol settings for service code cqg. Request ID: 5. 2024-08-05 13:55:40.216 | ESU24-CME[M] 3.75 Range #7 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:55:40.855 | ESU24-CME[M] 3.75 Range #7 | Chart data loading complete. 2024-08-05 13:55:40.923 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. | Number times message added: 1 2024-08-05 13:55:42.127 | ESU24-CME[M] 3.75 Range #7 | Reloading chart. 2024-08-05 13:55:50.698 | ESU24-CME[M] 1 Sec #12 | Reloading chart. 2024-08-05 13:55:50.715 | Symbol settings received. Request ID: 5. 2024-08-05 13:55:51.300 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 13:55:51.511 | F.US.EPU24[M] 5 Min #3 | Reloading chart. 2024-08-05 13:55:51.780 | F.US.EPU24[M] 5 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:51.780 | F.US.EPU24[M] 5 Min #3 | Chart data loading complete. 2024-08-05 13:55:51.786 | F.US.EPU24[M] 15 Min #2 | Reloading chart. 2024-08-05 13:55:52.166 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 19:59:59.963000. 2024-08-05 13:55:52.166 | F.US.EPU24[M] 15 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:52.166 | F.US.EPU24[M] 15 Min #2 | Chart data loading complete. 2024-08-05 13:55:52.186 | F.US.EPU24[M] 5 Min #1 | Reloading chart. 2024-08-05 13:55:52.205 | Loading market depth data. 2024-08-05 13:55:52.257 | Loaded depth data records for ESU24-CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 19:59:59.993000. 2024-08-05 13:55:52.571 | F.US.EPU24[M] 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:52.571 | F.US.EPU24[M] 5 Min #1 | Chart data loading complete. 2024-08-05 13:55:52.582 | Enabling compression for file: C:\SierraChart\Data\F.US.MESU24.scid 2024-08-05 13:55:52.583 | F.US.MESU24[M] #3 | Reloading chart. 2024-08-05 13:55:52.585 | F.US.MESU24[M] #3 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:55:52.585 | F.US.MESU24[M] #3 | Chart data loading complete. 2024-08-05 13:55:52.700 | F.US.EPU24[M] 1 Min #4 | Reloading chart. 2024-08-05 13:55:52.714 | Loading market depth data. 2024-08-05 13:55:52.956 | F.US.EPU24[M] 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:52.956 | F.US.EPU24[M] 1 Min #4 | Chart data loading complete. 2024-08-05 13:55:52.960 | F.US.EPU24[M] #2 | Reloading chart. 2024-08-05 13:55:53.197 | F.US.EPU24[M] #2 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:55:53.199 | F.US.EPU24[M] #2 | Chart data loading complete. 2024-08-05 13:55:53.342 | F.US.EPU24[M] 5 Min #6 | Reloading chart. 2024-08-05 13:55:53.601 | F.US.EPU24[M] 5 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.601 | F.US.EPU24[M] 5 Min #6 | Chart data loading complete. 2024-08-05 13:55:53.614 | F.US.EPU24[M] #8 | Reloading chart. 2024-08-05 13:55:53.728 | F.US.EPU24[M] #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.733 | F.US.EPU24[M] #8 | Chart data loading complete. 2024-08-05 13:55:53.737 | F.US.EPU24[M] 30 Min #1 | Reloading chart. 2024-08-05 13:55:53.742 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 15:39:06.271000. 2024-08-05 13:55:53.748 | F.US.EPU24[M] 5 Min #5 | Reloading chart. 2024-08-05 13:55:53.749 | Loaded depth data records for ESU24-CME 2024-08-01 from 2024-07-31 20:00:00.002000 to 2024-08-01 04:59:11.246000. 2024-08-05 13:55:53.750 | Loaded depth data records for ESU24-CME 2024-08-01 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.753 | Loaded depth data records for ESU24-CME 2024-08-02 from 00:00:00.000000 to 00:00:00.000000. | Number times message added: 1 2024-08-05 13:55:53.755 | Loaded depth data records for ESU24-CME 2024-08-03 from 00:00:00.000000 to 00:00:00.000000. | Number times message added: 1 2024-08-05 13:55:53.760 | Loaded depth data records for ESU24-CME 2024-08-05 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.760 | ESU24-CME[M] 5 Min #5 | Chart Data Loading Thread: Load canceled. 2024-08-05 13:55:53.761 | Loaded depth data records for ESU24-CME 2024-08-05 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.761 | ESU24-CME[M] 30 Min #1 | Chart Data Loading Thread: Load canceled. 2024-08-05 13:55:53.764 | F.US.EPU24[M] 5 Min #3 | Reloading chart. 2024-08-05 13:55:53.768 | Restarting the loading process. | Number times message added: 1 2024-08-05 13:55:53.789 | Loading market depth data. | Number times message added: 1 2024-08-05 13:55:53.825 | F.US.EPU24[M] 5 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.825 | F.US.EPU24[M] 5 Min #3 | Chart data loading complete. 2024-08-05 13:55:53.826 | F.US.EPU24[M] 5 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.826 | F.US.EPU24[M] 5 Min #5 | Chart data loading complete. 2024-08-05 13:55:53.827 | F.US.EPU24[M] 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.827 | F.US.EPU24[M] 30 Min #1 | Chart data loading complete. 2024-08-05 13:55:53.832 | F.US.EPU24[M] 20000 Volume #10 | Reloading chart. 2024-08-05 13:55:53.850 | F.US.EPU24[M] 20000 Volume #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.850 | F.US.EPU24[M] 20000 Volume #10 | Chart data loading complete. 2024-08-05 13:55:53.858 | F.US.EPU24[M] 1 Min #11 | Reloading chart. 2024-08-05 13:55:53.861 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 07:12:05.121000. 2024-08-05 13:55:53.862 | Loaded depth data records for ESU24-CME 2024-08-01 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.862 | Loaded depth data records for ESU24-CME 2024-08-02 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.863 | Loaded depth data records for ESU24-CME 2024-08-03 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.863 | Loaded depth data records for ESU24-CME 2024-08-05 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.863 | ESU24-CME[M] 1 Min #11 | Chart Data Loading Thread: Load canceled. 2024-08-05 13:55:53.870 | F.US.EPU24[M] Daily #15 | Reloading chart. 2024-08-05 13:55:53.878 | Restarting the loading process. 2024-08-05 13:55:53.896 | F.US.EPU24[M] 240 Min #5 | Reloading chart. 2024-08-05 13:55:53.898 | Loading market depth data. 2024-08-05 13:55:53.905 | F.US.EPU24[M] 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.905 | F.US.EPU24[M] 1 Min #11 | Chart data loading complete. 2024-08-05 13:55:53.907 | F.US.EPU24[M] Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:55:53.907 | F.US.EPU24[M] Daily #15 | Chart data loading complete. 2024-08-05 13:55:53.908 | F.US.EPU24[M] 240 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.908 | F.US.EPU24[M] 240 Min #5 | Chart data loading complete. 2024-08-05 13:55:53.914 | F.US.EPU24[M] 30 Min #1 | Reloading chart. 2024-08-05 13:55:53.922 | F.US.EPU24[M] 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.922 | F.US.EPU24[M] 30 Min #1 | Chart data loading complete. 2024-08-05 13:55:53.926 | F.US.EPU24[M] 60 Min #4 | Reloading chart. 2024-08-05 13:55:53.935 | F.US.EPU24[M] 60 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.935 | F.US.EPU24[M] 60 Min #4 | Chart data loading complete. 2024-08-05 13:55:53.941 | F.US.EPU24[M] Weekly #7 | Reloading chart. 2024-08-05 13:55:53.953 | F.US.EPU24[M] 5 Min #2 | Reloading chart. 2024-08-05 13:55:53.953 | Loaded depth data records for ESU24-CME 2024-07-31 from 2024-07-30 20:00:00.001000 to 2024-07-31 15:59:46.128000. 2024-08-05 13:55:53.953 | Loaded depth data records for ESU24-CME 2024-08-01 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.953 | Loaded depth data records for ESU24-CME 2024-08-02 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.954 | Loaded depth data records for ESU24-CME 2024-08-03 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.954 | Loaded depth data records for ESU24-CME 2024-08-05 from 00:00:00.000000 to 00:00:00.000000. 2024-08-05 13:55:53.954 | ESU24-CME[M] 5 Min #2 | Chart Data Loading Thread: Load canceled. 2024-08-05 13:55:53.959 | Restarting the loading process. 2024-08-05 13:55:53.974 | Loading market depth data. 2024-08-05 13:55:53.977 | F.US.EPU24[M] Weekly #7 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:55:53.977 | F.US.EPU24[M] Weekly #7 | Chart data loading complete. 2024-08-05 13:55:53.978 | F.US.EPU24[M] 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:53.978 | F.US.EPU24[M] 5 Min #2 | Chart data loading complete. 2024-08-05 13:55:53.984 | F.US.EPU24[M] #4 | Reloading chart. 2024-08-05 13:55:53.994 | F.US.EPU24[M] #4 | StartDateTimeForLoadingOrderFills: 2024-07-22 00:00:00 2024-08-05 13:55:53.996 | F.US.EPU24[M] #4 | Chart data loading complete. 2024-08-05 13:55:54.004 | F.US.EPU24[M] 30 Min #6 | Reloading chart. 2024-08-05 13:55:54.015 | F.US.EPU24[M] 30 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:54.015 | F.US.EPU24[M] 30 Min #6 | Chart data loading complete. 2024-08-05 13:55:54.018 | F.US.EPU24[M] 3.75 Range #7 | Reloading chart. 2024-08-05 13:55:54.018 | Loading market depth data. 2024-08-05 13:55:54.018 | ESU24-CME[M] 3.75 Range #7 | Chart Data Loading Thread: Load canceled. 2024-08-05 13:55:54.021 | Restarting the loading process. 2024-08-05 13:55:54.024 | Loading market depth data. 2024-08-05 13:55:54.026 | F.US.EPU24[M] 3.75 Range #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:54.026 | F.US.EPU24[M] 3.75 Range #7 | Chart data loading complete. 2024-08-05 13:55:54.030 | F.US.EPU24[M] 1 Sec #12 | Reloading chart. 2024-08-05 13:55:54.030 | Loading market depth data. 2024-08-05 13:55:54.030 | ESU24-CME[M] 1 Sec #12 | Chart Data Loading Thread: Load canceled. 2024-08-05 13:55:54.033 | Restarting the loading process. 2024-08-05 13:55:54.038 | Loading market depth data. 2024-08-05 13:55:54.041 | F.US.EPU24[M] 1 Sec #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU24.scid 2024-08-05 13:55:54.041 | F.US.EPU24[M] 1 Sec #12 | Chart data loading complete. 2024-08-05 13:55:54.044 | 2024-08-05 13:55:54.045 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 13:55:54.045 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 13:55:54.045 | CQG WebSocket socket (4) | Creating socket. Using TLS 1.2. 2024-08-05 13:55:54.046 | CQG WebSocket socket (4) | New receive buffer size: 0 2024-08-05 13:55:54.046 | CQG WebSocket socket (4) | Connecting to IP: 195.166.124.175. 2024-08-05 13:55:54.106 | CQG WebSocket | Opening WebSocket. 2024-08-05 13:55:54.106 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 13:55:54.289 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 13:55:54.289 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 13:55:54.289 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 5MD4psD1GBQ7VyRf5ml4BoSuO70= 2024-08-05 13:55:54.289 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 13:55:54.289 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 13:55:54.289 | CQG WebSocket | Server header | 2024-08-05 13:55:54.289 | CQG WebSocket | Web socket state is now open. 2024-08-05 13:55:54.289 | CQG WebAPI | WebSocket connected. 2024-08-05 13:55:54.289 | CQG WebAPI | Sending market data logon message. 2024-08-05 13:55:54.556 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 13:55:54.556 | CQG WebAPI | Logon successful. Session Token = yHLzNr8xnbiw5GMIvCi16/Qz5EyWD6gegVCNhk5qgvI8fhTh7ZOMXToYPxC861F9ds3h3DJSvBZ 2024-08-05 13:55:54.556 | CQG WebAPI | Connected to server complete. 2024-08-05 13:55:54.557 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 13:55:54.557 | Updated verified funded futures trading account ending date to: 2024-09-04 12:55:54 2024-08-05 13:55:54.559 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 13:55:54.574 | Using symbol data fast lookup vector 2024-08-05 13:55:54.575 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 1 2024-08-05 13:55:54.575 | Symbol Error | F.US.MESU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 1 2024-08-05 13:55:54.575 | CQG WebAPI | Using primary service for historical data for F.US.MESU24 2024-08-05 13:55:54.575 | No historical data client is currently set to download historical Intraday data for F.US.MESU24. 2024-08-05 13:55:54.575 | Real-time Intraday chart data file updates started for F.US.MESU24 2024-08-05 13:55:54.575 | Intraday chart data file opened for F.US.MESU24 2024-08-05 13:55:54.608 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 2 2024-08-05 13:55:54.608 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 2 2024-08-05 13:55:54.608 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 13:55:54.608 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 13:55:54.608 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 13:55:54.608 | Intraday chart data file opened for F.US.EPU24 2024-08-05 13:55:54.689 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 13:55:54.689 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 13:55:54.693 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 13:55:54.693 | Updated verified funded futures trading account ending date to: 2024-09-04 12:55:54 2024-08-05 13:55:54.693 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 13:55:54.808 | CQG WebAPI | Sending positions subscribe request. RequestID: 741921 2024-08-05 13:55:54.808 | CQG WebAPI | Sending orders subscribe request. RequestID: 741922 2024-08-05 13:55:59.554 | Requesting market depth updates for: F.US.MESU24 if supported. NumLevels=100 2024-08-05 13:55:59.554 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24 2024-08-05 13:56:03.870 | F.US.EPU24 Daily #15 | Reloading chart. 2024-08-05 13:56:03.913 | F.US.EPU24 Daily #15 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:56:03.914 | F.US.EPU24 Daily #15 | Chart data loading complete. 2024-08-05 13:56:03.936 | F.US.EPU24 Weekly #7 | Reloading chart. 2024-08-05 13:56:03.949 | F.US.EPU24 Weekly #7 | StartDateTimeForLoadingOrderFills: 2024-08-02 00:00:00 2024-08-05 13:56:03.950 | F.US.EPU24 Weekly #7 | Chart data loading complete. 2024-08-05 14:02:11.733 | File >> Reconnect selected. 2024-08-05 14:02:11.736 | CQG WebAPI | Sending Web API Logoff message. 2024-08-05 14:02:11.736 | CQG WebSocket socket (4) | CloseSocket call. 2024-08-05 14:02:11.736 | CQG WebSocket | WebSocket closed. 2024-08-05 14:02:11.736 | CQG WebAPI | WebSocket closed. 2024-08-05 14:02:11.736 | CQG WebAPI | Disconnected. 2024-08-05 14:02:11.736 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 14:02:11.736 | CQG WebSocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 14:02:11.862 | CQG WebSocket socket (4) | Write has completed. Shutdown being performed. 2024-08-05 14:02:11.862 | CQG WebSocket socket (4) | Shutdown started. Waiting for graceful close. 2024-08-05 14:02:11.913 | CQG WebSocket socket (4) | Socket gracefully closed by remote side. 2024-08-05 14:02:11.913 | CQG WebSocket socket (4) | Closed. 2024-08-05 14:02:13.737 | 2024-08-05 14:02:13.737 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 14:02:13.738 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 14:02:14.157 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-05 14:02:14.157 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-05 14:02:14.157 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-05 14:02:14.214 | CQG WebSocket | Opening WebSocket. 2024-08-05 14:02:14.214 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 14:02:14.432 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 14:02:14.432 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 14:02:14.432 | CQG WebSocket | Server header | Sec-WebSocket-Accept: aLf8bGXhcyKJ5cZeqVhO03+b5DQ= 2024-08-05 14:02:14.432 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 14:02:14.432 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 14:02:14.432 | CQG WebSocket | Server header | 2024-08-05 14:02:14.432 | CQG WebSocket | Web socket state is now open. 2024-08-05 14:02:14.432 | CQG WebAPI | WebSocket connected. 2024-08-05 14:02:14.432 | CQG WebAPI | Sending market data logon message. 2024-08-05 14:02:14.761 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 14:02:14.761 | CQG WebAPI | Logon successful. Session Token = Zi2nTrIxVdj8MkBHXF5faH3oCID+rfq+lxcO3iWSa4IT+IAc+us+B8Za3/t2ckTNbdi7Ev+PNqC 2024-08-05 14:02:14.761 | CQG WebAPI | Connected to server complete. 2024-08-05 14:02:14.763 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 14:02:14.763 | Updated verified funded futures trading account ending date to: 2024-09-04 13:02:14 2024-08-05 14:02:14.768 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 14:02:14.876 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 14:02:14.876 | Updated verified funded futures trading account ending date to: 2024-09-04 13:02:14 2024-08-05 14:02:14.876 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 14:02:14.890 | Using symbol data fast lookup vector 2024-08-05 14:02:14.890 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 14:02:14.891 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 14:02:14.891 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 14:02:14.891 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 14:02:14.891 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 14:02:14.891 | Intraday chart data file opened for F.US.EPU24 2024-08-05 14:02:14.957 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 14:02:14.957 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 14:02:15.024 | CQG WebAPI | Sending positions subscribe request. RequestID: 741925 2024-08-05 14:02:15.024 | CQG WebAPI | Sending orders subscribe request. RequestID: 741926 2024-08-05 14:02:15.195 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2 2024-08-05 14:02:15.195 | Symbol Error | F.US.MESU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2 2024-08-05 14:02:15.195 | CQG WebAPI | Using primary service for historical data for F.US.MESU24 2024-08-05 14:02:15.195 | No historical data client is currently set to download historical Intraday data for F.US.MESU24. 2024-08-05 14:02:15.195 | Real-time Intraday chart data file updates started for F.US.MESU24 2024-08-05 14:02:15.195 | Intraday chart data file opened for F.US.MESU24 2024-08-05 14:02:19.770 | Requesting market depth updates for: F.US.MESU24 if supported. NumLevels=100 2024-08-05 14:02:19.770 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24 2024-08-05 14:07:08.408 | File >> Reconnect selected. 2024-08-05 14:07:08.412 | CQG WebAPI | Sending Web API Logoff message. 2024-08-05 14:07:08.412 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-05 14:07:08.412 | CQG WebSocket | WebSocket closed. 2024-08-05 14:07:08.412 | CQG WebAPI | WebSocket closed. 2024-08-05 14:07:08.412 | CQG WebAPI | Disconnected. 2024-08-05 14:07:08.412 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 14:07:08.412 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 14:07:08.469 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-05 14:07:08.469 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-05 14:07:08.525 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-05 14:07:08.526 | CQG WebSocket socket (1) | Closed. 2024-08-05 14:07:10.413 | 2024-08-05 14:07:10.413 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 14:07:10.413 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 14:07:10.415 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-05 14:07:10.415 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-05 14:07:10.415 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-05 14:07:10.470 | CQG WebSocket | Opening WebSocket. 2024-08-05 14:07:10.470 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 14:07:10.673 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 14:07:10.673 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 14:07:10.673 | CQG WebSocket | Server header | Sec-WebSocket-Accept: S0JKVJcROTccfwAVXMUMFB9P/IM= 2024-08-05 14:07:10.673 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 14:07:10.673 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 14:07:10.673 | CQG WebSocket | Server header | 2024-08-05 14:07:10.673 | CQG WebSocket | Web socket state is now open. 2024-08-05 14:07:10.673 | CQG WebAPI | WebSocket connected. 2024-08-05 14:07:10.673 | CQG WebAPI | Sending market data logon message. 2024-08-05 14:07:10.937 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 14:07:10.937 | CQG WebAPI | Logon successful. Session Token = aKalvHtit8SANomFpZ3u76v4jzaWFESjoJSnrPSg4ZIVDRaM/5rv6nwBojJ9osMefD+clvitZYv 2024-08-05 14:07:10.937 | CQG WebAPI | Connected to server complete. 2024-08-05 14:07:10.938 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 14:07:10.938 | Updated verified funded futures trading account ending date to: 2024-09-04 13:07:10 2024-08-05 14:07:10.944 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 14:07:11.082 | Using symbol data fast lookup vector 2024-08-05 14:07:11.082 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 14:07:11.082 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 14:07:11.082 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 14:07:11.082 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 14:07:11.082 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 14:07:11.082 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 14:07:11.082 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 14:07:11.082 | Intraday chart data file opened for F.US.EPU24 2024-08-05 14:07:11.098 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 14:07:11.098 | Updated verified funded futures trading account ending date to: 2024-09-04 13:07:11 2024-08-05 14:07:11.098 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 14:07:11.181 | CQG WebAPI | Sending positions subscribe request. RequestID: 741929 2024-08-05 14:07:11.182 | CQG WebAPI | Sending orders subscribe request. RequestID: 741930 2024-08-05 14:07:11.334 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2 2024-08-05 14:07:11.334 | Symbol Error | F.US.MESU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2 2024-08-05 14:07:11.334 | CQG WebAPI | Using primary service for historical data for F.US.MESU24 2024-08-05 14:07:11.334 | No historical data client is currently set to download historical Intraday data for F.US.MESU24. 2024-08-05 14:07:11.334 | Real-time Intraday chart data file updates started for F.US.MESU24 2024-08-05 14:07:11.334 | Intraday chart data file opened for F.US.MESU24 2024-08-05 14:07:15.935 | Requesting market depth updates for: F.US.MESU24 if supported. NumLevels=100 2024-08-05 14:07:15.935 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24 2024-08-05 14:08:15.605 | File >> Reconnect selected. 2024-08-05 14:08:15.609 | CQG WebAPI | Sending Web API Logoff message. 2024-08-05 14:08:15.609 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-05 14:08:15.609 | CQG WebSocket | WebSocket closed. 2024-08-05 14:08:15.609 | CQG WebAPI | WebSocket closed. 2024-08-05 14:08:15.609 | CQG WebAPI | Disconnected. 2024-08-05 14:08:15.609 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-05 14:08:15.609 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-05 14:08:15.695 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-05 14:08:15.695 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-05 14:08:15.746 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-05 14:08:15.746 | CQG WebSocket socket (1) | Closed. 2024-08-05 14:08:17.609 | 2024-08-05 14:08:17.609 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-05 14:08:17.609 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-05 14:08:17.610 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-05 14:08:17.610 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-05 14:08:17.610 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-05 14:08:17.731 | CQG WebSocket | Opening WebSocket. 2024-08-05 14:08:17.731 | CQG WebSocket | Sending WebSocket handshake. 2024-08-05 14:08:17.928 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-05 14:08:17.928 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-05 14:08:17.928 | CQG WebSocket | Server header | Sec-WebSocket-Accept: fuloPpAE9zMJElM1QgG9iJJTZMQ= 2024-08-05 14:08:17.928 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-05 14:08:17.928 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-05 14:08:17.928 | CQG WebSocket | Server header | 2024-08-05 14:08:17.928 | CQG WebSocket | Web socket state is now open. 2024-08-05 14:08:17.928 | CQG WebAPI | WebSocket connected. 2024-08-05 14:08:17.928 | CQG WebAPI | Sending market data logon message. 2024-08-05 14:08:18.230 | CQG WebAPI | Base Time: 2024-08-04T06:20:44. 2024-08-04 06:20:44 2024-08-05 14:08:18.230 | CQG WebAPI | Logon successful. Session Token = KHQlmbeSMX24ZqfQef8cY7cTE1MOhRpUrFDgkDS5fAYhWnWMC3+c3ulOg74Efb4rT5qnN2Jzq2G 2024-08-05 14:08:18.230 | CQG WebAPI | Connected to server complete. 2024-08-05 14:08:18.231 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-05 14:08:18.231 | Updated verified funded futures trading account ending date to: 2024-09-04 13:08:18 2024-08-05 14:08:18.237 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-05 14:08:18.353 | CQG WebAPI | Brokerage name: AMP. Account Name: 150246 2024-08-05 14:08:18.353 | Updated verified funded futures trading account ending date to: 2024-09-04 13:08:18 2024-08-05 14:08:18.353 | CQG WebAPI | Sending collateral subscribe request. 2024-08-05 14:08:18.429 | Using symbol data fast lookup vector 2024-08-05 14:08:18.429 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 14:08:18.429 | Symbol Error | F.US.EPU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24. ID: 1 2024-08-05 14:08:18.429 | CQG WebAPI | Using primary service for historical data for F.US.EPU24 2024-08-05 14:08:18.429 | No historical data client is currently set to download historical Intraday data for F.US.EPU24. 2024-08-05 14:08:18.429 | Real-time Intraday chart data file updates started for F.US.EPU24 2024-08-05 14:08:18.429 | Intraday chart data file opened for F.US.EPU24 2024-08-05 14:08:18.446 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-08-05 14:08:18.446 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU24 2024-08-05 14:08:18.459 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2 2024-08-05 14:08:18.459 | Symbol Error | F.US.MESU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2 2024-08-05 14:08:18.459 | CQG WebAPI | Using primary service for historical data for F.US.MESU24 2024-08-05 14:08:18.459 | No historical data client is currently set to download historical Intraday data for F.US.MESU24. 2024-08-05 14:08:18.459 | Real-time Intraday chart data file updates started for F.US.MESU24 2024-08-05 14:08:18.459 | Intraday chart data file opened for F.US.MESU24 2024-08-05 14:08:18.494 | CQG WebAPI | Sending positions subscribe request. RequestID: 741933 2024-08-05 14:08:18.494 | CQG WebAPI | Sending orders subscribe request. RequestID: 741934 2024-08-05 14:08:23.229 | Requesting market depth updates for: F.US.MESU24 if supported. NumLevels=100 2024-08-05 14:08:23.229 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24 |
[2024-08-05 15:17:40] |
This is the issue: 2024-08-05 14:08:18.459 | Symbol Error | F.US.MESU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.MESU24. ID: 2
We do not have support for data from CQG for The CME Group and EUREX. Therefore, you would need to get this data from our Denali Exchange Data Feed. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
