Date/Time: Sat, 23 Nov 2024 17:58:42 +0000
cqg / amp futures and tesla
View Count: 186
[2024-08-05 11:54:12] |
SafSaf - Posts: 89 |
alright lads, i'm currently on the cqg feed trading futures through amp and now i'd like to also trade tesla but i'm not sure of the settings and feeds?... i can't set myself up on denali through amp
[2024-08-05 12:03:51] |
update... i've just checked my account and it seems i applied for and signed all the agreements necessary for me to trade stocks but my application was rejected on the basis my name was incorrect. can you please correct and update this as my first name and surname is indeed saffet saffet. i had the exact same problem when i first subscribed to sierra charts which you sorted. please do let me know if there is anything i need to do my side to start trading tesla and stocks.ta |
[2024-08-05 15:04:02] |
You need to redo the agreements. Once they are rejected we can not change that status. Also, keep in mind that you can not trade equities with AMP. AMP only does futures trading. The only broker we connect with that offers trading of U.S. Equities is Interactive Brokers. Refer to the following: Interactive Brokers Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-05 15:23:57] |
I have an account with interactive brokers so that’s no problem. Regarding redoing the agreements I can’t until they are taken off. I don’t have the option. Also if I add interactive brokers do I need to start a new instance of sierra?
[2024-08-05 15:48:31] |
We do not understand this. You can redo the agreements by creating new ones. For the U.S. Equities Consolidated Tape, the agreement is at the following link: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements_STOCKS Also if I add interactive brokers do I need to start a new instance of sierra?
You will need to have a separate installation of Sierra Chart on the same computer. This way, one installation can be connected to AMP and the other to Interactive Brokers. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-05 16:11:25] |
Can you pls check if I have signed them properly. I clicked on the first link and filled in the incomplete documents and signed them. All the other documents which are in the list say rejected and I cannot change or sign any of those?
[2024-08-05 17:46:35] |
You do not edit the already signed agreements. You need to enter a new agreement by selecting the link for the agreement in the section entitled "Real-Time Data Agreements". For the U.S. Equities Consolidated Tape the agreement link states "UTP-NASDAQ CTA-NYSE Non-Professional Certification". You may see the word "Submitted" next to the link - just ignore that and select the link and fill out the document again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
