Date/Time: Sat, 23 Nov 2024 16:53:07 +0000
Trial account for demonstration
View Count: 125
[2024-08-05 11:48:36] |
User368075 - Posts: 15 |
Hi guys, I have a community of traders and I’m showing them how to use Sierra Chart. I saw that they are having problem setting Sierra properly with delayed data. Can I have a trial account to show them how to configure Sierra? Thank you
[2024-08-05 14:59:29] |
You can create another account and it will be setup on a trial. You can then use that for what you need. If you are having a problem with this, let us know. Also, keep in mind that we have changed the way we do trials, so we no longer have an activation process. Trials now only have access to limited data. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-06 09:31:51
[2024-08-05 15:38:13] |
Perfect! Thank you
[2024-08-06 09:31:59] |
Sierra_Chart Engineering - Posts: 17150 |
Let us know if you need more help.
