Date/Time: Sat, 23 Nov 2024 17:58:41 +0000
Market Data Question
View Count: 102
[2024-08-05 02:50:02]
GereimyHernandez - Posts: 1
I recently opened an AMP Futured trading account and requested log in credentials for sierra charts. I have them already, now my question is , Do i need package 11 for the price of $46 dollars and Denali Exchange data too Worth $37.50 or do I only need package 11?
[2024-08-05 14:42:26]
Since you are with AMP and wanting data for the CME Group, you will need to get this data from us.
This is the case, as you are using either the Teton Order Routing Service or CQG with AMP. With Teton, the data comes from us. And with CQG, we do not have support for data from the CME Group and EUREX - hence you then have to get the data from us.
There are many options for the data from The CME Group, so if you do not need Market Depth for all 4 of the exchanges, then you can put together different exchange options that might be cheaper than the $37.50. But it does depend on your needs.
Follow the instructions at the following link to setup the CME Group data:
