Date/Time: Sat, 23 Nov 2024 17:51:44 +0000
ETH and RTH profiles
View Count: 116
[2024-08-04 23:21:59] |
User575399 - Posts: 322 |
For some reason i cannot change the RTH and RTH profile colors. I can only change the outline color. I followed the step by step process for allowing evening profiles and changed the time setting to allow. any ideas? Date Time Of Last Edit: 2024-08-05 00:02:55
Screenshot (113).png / V - Attached On 2024-08-04 23:21:53 UTC - Size: 189.25 KB - 52 views |
[2024-08-05 14:26:16] |
This is most likely due to the size of the bars being so small. So the outline is the only thing you are seeing. There is an option to not draw the outline with the "Bid/Ask" coloring. But it does not look like this is what you are using. Still, refer to the following: Volume By Price Study: Draw Outline When Coloring Bid Volume And Ask Volume The best option is to increase the "Ticks per Volume Bar", so the bars aren't so small. Refer to the following: Volume By Price Study: Ticks Per Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
