Date/Time: Sat, 23 Nov 2024 18:04:39 +0000
Number Bar replay with Rithmic data in 1 second blocks
View Count: 133
[2024-08-04 15:44:40]
HeyUgly - Posts: 247
Hello
Long time sierra user.
When i hit a replay with Denali, all works as it should. the orderflow on the number bars is fine, and replays pretty much exactly as it transacted.
When I replay it with Rithmic, the number bars move in exactly 1 second blocks, totally unnatural of the tape. Its exactly 1 second intervals.
This is replaying it at 1 speed, and wanting to see it as it came through. Is there any setting in the replay function that I'm not aware of to get the rithmic replay the same as Denali? This is not a new issue, its always been like this for me, for years.
Thanks in advance for any tips
[2024-08-04 15:47:33]
For reference - This is how it replays - file attached
imageSierraChart_64_wSSbjYqmEo.gif / V - Attached On 2024-08-04 15:47:18 UTC - Size: 52.51 KB - 39 views
[2024-08-04 17:02:15]
Sierra_Chart Engineering - Posts: 17150
There may not be a solution to this because we think the issue is that the particular message that Rithmic is using to provide market data does not support milliseconds.
