Date/Time: Sat, 23 Nov 2024 17:59:37 +0000
I can't connect on Teton, All Service is fine
View Count: 147
[2024-08-04 13:17:21] |
User849502 - Posts: 345 |
Hi, It is Sunday and thought I would look at charts. I can log on just fine with 'all service' but my Teton stays at yellow and says a 'secondary instance' is not allowing connection to the server. Yes, I have a secondary instance on this feed(though I haven't logged on to it in weeks). Please see attached pop-up. What do I do to correct this? I tried disconnecting from the data feed and reconnecting. Nothing happened. I can't trade on Monday until you help me fix this... thank you for your time. Karen |
Screenshot 2024-08-04 140122sc.png / V - Attached On 2024-08-04 13:16:14 UTC - Size: 65.64 KB - 35 views |
[2024-08-04 13:19:36] |
here is trade service settings. I have done nothing to any setting since logging off on Friday.
[2024-08-04 13:21:46] |
I sent the logs to you as well
[2024-08-04 13:32:20] |
Sierra_Chart Engineering - Posts: 17150 |
We are doing maintenance now on the server. It will be finished in about 30 minutes.
