Date/Time: Sat, 23 Nov 2024 18:14:03 +0000
Hotkeys for switching between different bracket orders
View Count: 171
[2024-08-04 11:55:40] |
User700382 - Posts: 12 |
Hi! I was wondering if it is possible to set up some hotkeys to switch between different bracket orders while trading, so I don't have to do it manually by opening the trade window and looking for the bracket order I need. For example, sometimes I don't need a larger stop loss when I'm looking for a quick scalp, while other times I need it to capture a bigger move. Dragging it from the DOM could be a solution, but adjusting it takes too much time and can be complicated when the market is very volatile. Thank you. |
[2024-08-05 00:14:28] |
ondafringe - Posts: 283 |
If you can code, you can set that up in a custom study.
[2024-08-05 14:30:36] |
You do this by changing your "Trade Configurations". You can setup keyboard shortcuts and/or Control Bar buttons for different trade configurations. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
