Date/Time: Sat, 23 Nov 2024 16:48:44 +0000
Depth of Market Data Study in replay
View Count: 173
[2024-08-03 04:04:57] |
User745789 - Posts: 313 |
The study "Depth of Market Data" doesn't get any data during replay. I have confirmed that the "Market Depth Historical Graph" study does get data in replay. Is "Depth of Market Data" study not eligible for replay? |
[2024-08-05 13:32:43] |
The "Depth of Market" study can be used with a Replay. There just has to be the Market Depth data stored in order to have the study work properly. But it sounds like you have this correct, since you state that the "Market Depth Historical Graph" is displaying. Do you have the Market Depth displayed in the DOM? Are you seeing all the levels in there during a replay? What "Replay Mode" are you using for the replay? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-06 00:17:09] |
Thank you for the reply. I have depth displayed in the DOM, and am using the most accurate relay mode.
[2024-08-06 14:29:28] |
We are not seeing any issues with the "Depth of Market" study during a replay. Please get us a chart that shows this issue by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart And please tell us the settings you are using in the Replay window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
